Pan & Tilt for the Stingray? Why not!
Alex over at Crust Crawler was testing his S3 Pan/Tilt with a camera on the Stingray and we're all happy to report it mounts and works great!· Attached are some pictures.· Enjoy!·
Don't forget...on the horizon are some wheel encoders and eventually a line follower for the Stingray as well.· And currently development continues on a gripper for the Stingray!· Yes, you heard me right...I did say gripper.·
Chris Savage
Parallax Engineering
Check out the new Savage Circuits TV!
Chris Savage
Will this gripper be on an arm, or just attached to the front?
Do you have any ETAs on anything for the stingray?
Check out the Propeller Wiki·and contribute if you can.
Whit+
Jax
If a robot has a screw then it must be romoved and hacked into..
Height - 75mm
Width - 72mm
Center-to-Center for vertical slots - 10mm
Center-to-Center for·horizontal slots - 7mm
Center-to-Center for vertical holes -11mm
Center hole for grommet/wiring - 13mm
Duffer
Post Edited (Duffer) : 1/13/2010 12:05:49 AM GMT
Jax
Chris Savage
