DuePoint calculation question? — Parallax Forums
JavalinJavalin Posts: 892
edited 2010-01-09 20:56 in General Discussion
Afternoon all,
Whats the symbol in this equation mean?· The one after the "b" and the minus.
This is from :· http://en.wikipedia.org/wiki/Dew_point
James
  • danieldaniel Posts: 231
    edited 2010-01-09 19:13
    Using 'y' as 'that symbol' (incidentally, 'that symbol' looks to be the Greek letter gamma in lower case)...
    The y(T,RH) is meant to be treated as the result of a particular function (calculation) involving T (temperature) and RH (relative humidity).
    The calculation ifof y(T,RH) is presented as the next formula on that wikipedia page.
    daniel
    Post Edited (daniel) : 1/9/2010 9:08:02 PM GMT
    edited 2010-01-09 19:16
    It means "function of T and RH". The next line explains exactly what the function is. You plug T and RH into the second formula and then plug the result back into the first formula.
    Tracy Allen
    www.emesystems.com
  • JavalinJavalin Posts: 892
    Thanks Both.
