Stingray Motor Shaft Encoders — Parallax Forums
Sal AmmoniacSal Ammoniac Posts: 213
edited 2011-09-28 04:37 in Robotics
Has anyone come up with a good way to attach a shaft encoder to the armature shaft of the motors on a Stingray?
«13
  • DufferDuffer Posts: 374
    edited 2010-01-05 15:26
    These http://www.lynxmotion.com/Product.aspx?productID=448&CategoryID=
    look like they would do nicely. From the assembly instructions the motor shown looks the same as the motors used by Parallax.
    Duffer
    edited 2010-01-05 17:06
    Duffer, thanks for pointing those out. The motors are almost the same, the difference is the gear ratios. The two 7.2v motors at lynxmotion are 175RPM or 291RPM while the Stingray motors are 310RPM, but that shouldn't matter for the encoders. The area where the encoders mount looks identical.
    I've ordered a couple of these and will post here after I've gotten them and tested them out.
    Check out the Propeller Wiki·and contribute if you can.
  • TimmooreTimmoore Posts: 1,031
    edited 2010-01-05 17:15
    These encoders are usdigital encoder. I have used these on other projects and I have a Stingray. The encoders should fit fine. If you go to usdigital.com you can get more options for the encoders.
  • WhitWhit Posts: 4,194
    edited 2010-01-05 17:18
    Sal, Duffer and Roy,
    Great find. I look forward to hearing how this comes out.
    Whit+
    edited 2010-01-05 19:59
    I checked out the USDigital.com site and found the one the lynxmotion is selling, and in order to get similar pricing you'd have to by 10 or more and you'd have to buy the cables seperately.
    Anyway, they do have a ton of options and different encoders, so it's a good site to save for possible future needs. Thanks!
    edited 2010-01-05 20:43
    I also did notice that on one of Chris Savage's previous Stingray posts that Parallax did consider a US Digital encoder.
    Whit+
  • Ray0665Ray0665 Posts: 231
    edited 2010-01-09 19:04
    Hi: I purchased these encoders from Linxmotion part# QME-01 $26 ea and they installed just fine mechanically,
    however, I am having a problem I don't yet understand.
    I have connected the A/B signals to Ports 3,4,5,6 on the stingray and am seeing a 4V signal as observed using the parallax usb o-scope, however at the output of the level shifters I am seeing a very intermittent signal. Sometimes at 3V sometimes at 1V or less.
    As an aside I have written some test code that spins the wheels and then counts falling transitions stopping when some count is reached but so far it just spins the wheels without stopping (most likely just hangs waiting for a transition but I haven't checked yet)
    Anyone have any ideas?
    Update:
    The problem turns out to be a bad port on the voltage translator. Moving the encoder pin assignments solved the problem.
    So the bottom line is that the QME-01 encoders work just fine.
    I also just uploaded a new working encoder test program the original had several bugs
    Manually bump the wheel to start them turning (Dumb, I know, but hey its only a test)
    Ray
    Post Edited (Ray0665) : 1/11/2010 6:33:51 AM GMT
    edited 2010-01-09 19:16
    I'm still waiting for mine to arrive. UPS tracking says I'll get them on 1/12/2010.
    edited 2010-01-11 21:15
    Roy, as a note, encoders are the next accessory being worked on for the Stingray. And yes, the US Digital encdoers were tested however they were the E4 and E4P that we tested. One mounted via double-sided sticky tape. The other via a couple of screws through the plastic on the back of the motor.
    Chris Savage
    Parallax Engineering
    Check out the new Savage Circuits TV!
    edited 2010-01-11 22:03
    Chris: The ones available from LynxMotion are E4P-100-079-HT. They stick on via double sided tape. I expect that they will work ok, but will likely have a different numbers of "ticks" per rotation than whatever you settle on.
    I got them to "experiment with", and will likely end up getting whatever version you settle on from the Parallax store. I want to be able to use/share code that works with standard stuff.
    edited 2010-01-11 22:27
    Roy, I don't know...the US Digital encoders are very high resolution. When you consider on top of that the motor shaft is spinning many times (30) faster than the output shaft you have pretty fine resolution. I think they list from 100ppr to 400ppr for that encoder depending on which wheel you choose.
    Chris Savage
    edited 2010-01-11 22:52
    These are supposed to be 100ppr, so with the motor shaft spinning at 1500-2500 rpm that's 150k to 200k pulses per second. I figured a Prop input pin could handle that? Maybe I need some sort of divider circuit to make them work?
    edited 2010-01-12 01:04
    Roy, you should be okay, I will let you know what I come up with as well. Best Regards.
    Chris Savage
    edited 2010-01-12 16:48
    Roy, Chris
    Using my test program with the speed set to 90 I am seeing about 70 microseconds per pulse so this is well within the props capabilities.
    Ray
    edited 2010-01-12 19:40
    Hi All
    OK just to get things started, with these encoders here is a short turtle graphics like program that draws polygons with the Stingray.
    It uses the Linxmotion QME-01 wheel encoders for distance and turn calculations. Have fun.
    Ray
    edited 2010-01-13 00:07
    Ray0665,
    I got my QME-01 encoders today and installed them. I tried your program out and found things to be a little off with my Stingray. After checking out the code and doing some experimenting I believe I have things working reasonably well now.
    First, I think these motors might be 25:1 gear ratio instead of 30:1.· Using 2500 pulses per tire revolution resulted in reasonably accurate actual distances travelled by my Stingray. (So in the code if I say go 38cm, it travels 38cm on a flat wood surface.)
    Second, in your constants you had some stuff that was ending up doing integer math instead of (I assume) the intended float operations. Also, since runtime code can't do floats without a math library, I changed things so that it uses 10 cm, and 10 degrees in the constants and divides by 10 in the runtime. This made things more accurate for me.
    Third, I changed the motor driving stuff to drive each motor until it's counter reached the desired pulses. You were only checking counter A, and driving both motors based on that, but because of possible slipping (especially when turning) it needs to check both counters and drive the motors accordingly.
    I've attached my version of the Poly-1.spin code, for you to review.
    Post Edited (Roy Eltham) : 1/13/2010 12:21:32 AM GMT
    edited 2010-01-13 01:42
    Roy
    Thanks for looking at Poly-1, I'm glad you used it to get started, that was my intention.
    I am running my bot on a rug (short loop Berber) when I went to the hardwood floor the bot fishtailed on the turns throwing everything off because stop as written apparently just removes power from the motors and allows some coasting plus there is no speed ramping so some differences are expected.
    I am getting a repeatable 1 meter square (turning both left and right) and the bot ends up on the starting point oriented as it started with Poly-1 as written.
    When I downloaded your modified program I got an open figure with the bot oriented about 30 degrees left and about a foot from the starting point so we obviously have soom differences between our bots.
    Epmm is an integer divided by an integer with the results truncated to an integer. Since the units are in mm I did not see the need for more accuracy.
    For this simple demo program using one encoder on one wheel is good enough when I get around to actually doing odometry I'll certainly use both.
    Ray
    edited 2010-01-13 02:11
    Ray,
    Yeah, I'm no longer convinced my code is correct. I get different results depending on the number of sides I pick and at different speeds. I was getting a pretty consistent square 38cm to a side at speed 25 on the wood surface using my version, but with 6 or 8 sides it gets off track, and at faster speeds it is also off. However, I to see it "correcting" sometimes with the DriveMotors code checking both counters. Also, the coasting issue is notable on the wood surface. I think I was just getting lucky with my square working out.
    I am attempting to make my code ramp the motors up and down. Including starting the ramp down before it gets to the pulse count to reduce overshooting.
    Maybe Chris Savage can give us the definitive answer on the gear ratio for these motors?
    edited 2010-01-13 02:35
    Well your post got me looking again so I took my earlier encodercounttest.spin (above) set the speed very slow and set the count stoping point to 150000 pulses. After running it with these parameters it stops after 50 revolutions within 2 degrees of TDC so I'm at least convinced that the motors are 30:1
    A lot of stuff I read regarding the "Square test" uses 4 meters on a side. I suspect 38cm simply wasn't enough
    Good luck, have fun, over and out (for now anyway)
    Ray
    edited 2010-01-13 03:03
    Ray, Roy and others,
    This is great stuff! Glad you all are getting some good results.
    Whit+
    edited 2010-01-13 07:44
    So I'm done playing with the bot for tonight. I managed to get the Stingray to do a reasonably good square and an "alright" hexagon even if it wasn't really the "right way" I did "learn" a few things today that should get me closer to the right way next time I can play.
    1. The gear ratio is 30:1, even the docs say so. The reason I thought 25:1 was possible was because of doing things the wrong way and being in a hurry to "get results".
    2. Even with a reasonable load, when you tell a motor to stop, it keeps right on going for a little bit. (sometimes as much as 200-300 ticks on these encoders) Ramping up and down will likely help a bunch with this. Especially, slowing the motors down well before you get to the desired tick count so you can hit the count without overshooting it too much.
    3. My motors definitely run at different speeds given the same duty cycles on the controller. I need to write some code to drive the motors to a desired tick rate from the encoders instead of just using pwm duty cycles on the controller.
    3a. These motors take a reasonable PWM duty cycle level to get moving at all (15-25 depending on the surface), and this causes the slowest speed to not be that slow. Maybe different PWM methods will help here? Or do we need to get motors with higher gear ratios? (Lynxmotion has one with 50:1)
    Roy
    edited 2010-01-13 22:59
    Roy,
    Yeah, the motors were spec'd to be 30:1. If there is a variance it isn't intended on our part and I will do some further testing this weekend. I need to get out the US Digital encoders and check those out as well until we have a solution. This way I can compare with what you're seeing as well. Thanks for the feedback.
    Chris Savage
    edited 2010-01-13 23:46
    Chris,
    It seems like the motors and controller on the Stingray don't really do "braking". I've read some stuff that says typical h-bridge setups can do braking, but my testing on the Stingray shows no noticable difference in how hard it is to manually turn the wheels when the power is off verses when the power is on and the code is driving the motor controller with either 0,0 or 1,1 (the table in the docs say that that should be braking). I tried with 1 7.2v battery and with two in parallel (not that that would change much).
    I did notice that my motors make a high pitched whine sound when I have the code drive the motor controller to 1,1, but it didn't feel like it was doing any braking.
    Roy
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-01-14 02:34
    OK,
    I would love to play with this but I just don't have the time. The physics is there but...
    Has anyone tried mounting a magnet perpendicular to the shaft with hall effect sensor watching the field?
    Does a hobby motor spin up fast enough to distort the field?
    Can it·work?
    Jim-
    Signature space for rent!
    Send $1 to CannibalRobotics.com.
    edited 2010-01-14 07:25
    Roy,
    If you're running the code that spins the wheels full speed in one direction and you press the reset button, the wheels should come screeching to a halt. On the other hand, if you run the same code then quickly slide the power switch to the off position the motors should freewheel a bit. When the power switch is on, the H-Bridge is enabled and when both lines are at the same level braking is enabled. I can make a video if you like to demonstrate.
    Chris Savage
    edited 2010-01-14 09:04
    Chris,
    Ok, I just did a test like you described and I definitely notice the difference. I guess I was expecting a stronger braking than I should have.
    The thing I was noticing was that when I when I had reached my desired pulse count and stopped the motor, it was still going for another 50-200 pulses (which is ~ 6 to 24 degrees of the wheel). Obviously, this is because the motor can't stop instantly especially when the mass of the moving robot is factored in. I saw a lot less "overshooting" when I ran the motors at very slow speeds, so I know that if I change my code to ramp the speed down as I approach the desired pulse count I can more accurately hit my target distance (of course wheel slipping on the surface can't be accounted for here).
    Thanks for putting up with my trial and error learning and being nice and helpful in replies.
    edited 2010-01-14 20:29
    Roy, it's no problem. I understand that hearing braking you expect there to be some force stopping the wheels. What is happening is essentially you're shorting the motor leads together. That resists the motor spinning to some degree, but obviously not like stomping the brake pedal on your car. It is more subtle, however it's there and does help slow the bot. A few years back I was working on an active braking system for robots that moved fast but I ran out of time (I moved to CA) and never finished it, but my concept was to monitor the encoders and when the robot was supposed to stop, apply a reverse PWM proportional to how fast the wheels were moving when told to stop. In theory it should have worked great but I had a few problems that I never got to work out (mainly oscillation) and I never went back to it so I've forgotten most of it. But I intend to pick it back up here in the next month or two as the Stingray is a perfect candidate.
    Chris Savage
    edited 2010-01-14 22:58
    I had the same questions about the effectiveness of the braking. I just put the bot on an incline that was steep enough so that the bot would roll from its own weight (about a 13 on the stimpmeter). smilewinkgrin.gif· Then applied braking (0x1111 to the pins) and it was able to hold its own weight on the slope (but it can't putt worth a hoot!).
    I also got a pair of the LynxMotion wheel encoders (QME-01). They really go on nicely and the MSR1 is laid out nicely to accommodate the little two-wire connectors on the three-pin headers (pic below).
    Encoders are connected as follows:
    Right wheel power & GND at pin 8, Left wheel power & GND at pin 10.
    Right encoder outA to pin 8, Right encoder outB to pin 9, Left outB to pin 10 and Left outA to pin 11
    (the A&B outs are reversed in sequence for the left wheel so that forward movement·generates positive numbers·for forward movement and negative numbers for reverse movements just as the right wheel does).
    The LynxMotion QME-01 wheel encoders are connected and being read by the·'Quadrature_Encoder'··object.
    'PWM_32_v2' object will be used to drive the motors, but this first version lets you turn the wheels
    (gently)· by hand to observe and measure both the absolute (sum) of movements and the delta (change) from one reading to the next.
    The Absolute and Delta reading are displayed every 2 seconds to the Parallax Serial Terminal using the·'Extended_FDSerial' object
    This allows for some very accurate measurements. So far the following has been measured and·calculated:
    1 wheel revolution = 12,000 transitions or 15.12" forward movement (both of my wheels·are outputting exactly the same counts)
    That's exactly what the specs says it should be: 400 ppr with· 30:1 gearing.
    Stingray turning diameter is 10.77" or
    33.835" turning circumference or
    2.2377 wheel turns or
    26,853.2 transitions or
    74.59 transitions per degree of turn
    The turning figures have not yet been observed...More to follow. Attached is an Archive of what I have so far. I'm sooooo bummed! I have to be away for a few days and won't get a chance to play any more untill the middle of next week.
    Duffer
    Post Edited (Duffer) : 1/14/2010 11:50:54 PM GMT
    edited 2010-01-14 23:50
    Duffer
    I think you just set the standard for hooking up these encoders, I just switched.
    Your numbers sound very close to mine except I've been working in metric and trying to stay with integer math.
    I was just about to start playing around with that Quadrature encoder object so you made it easy for me.
    I'll download your archive now and let you know what I get.
    edited 2010-01-15 08:53
    Yeah Duffer, that's some great info and thanks for sharing your code. I'll be checking it out this weekend.
