IN3 is stuck — Parallax Forums
IN3 is stuck
goofybud16goofybud16 Posts: 9
edited 2010-01-08 23:28 in BASIC Stamp
When i program my basic stamp to use IN3 it will stay on 1, i changed the code to IN2 and it worked, then IN4, worked, back to IN3 and it stuck on 1 again. confused.gifconfused.gif
    edited 2010-01-08 03:32
    Maybe you did something to (whacked) that pin?
    (Maybe it's goofy bud?)
  • dandreaedandreae Posts: 1,375
    edited 2010-01-08 14:30
    What type of circuit did you have connected I/O pin 3?·
    Dave
    Dave Andreae
    Parallax Tech Support·
    edited 2010-01-08 18:09
    "Stuff happens".
    If you accidently blew output pin 3·via short circuit or such, it may still function as an input. If you can use it as an input, you're not stuck with a 15-pin Stamp. Test it and see.
  • goofybud16goofybud16 Posts: 9
    I had a push button on it. I have the Home Work board. Disconnected the battery, plugged it in the next day, and that was what happened. It did get moved a little while disconnected. Think it got shorted then or something like that happened. It controls a LED just fine, ON when it is set to, OFF when it was supposed to.
    goofybud16
