When i program my basic stamp to use IN3 it will stay on 1, i changed the code to IN2 and it worked, then IN4, worked, back to IN3 and it stuck on 1 again.
If you accidently blew output pin 3·via short circuit or such, it may still function as an input. If you can use it as an input, you're not stuck with a 15-pin Stamp. Test it and see.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ ·"If you build it, they will come."
I had a push button on it. I have the Home Work board. Disconnected the battery, plugged it in the next day, and that was what happened. It did get moved a little while disconnected. Think it got shorted then or something like that happened. It controls a LED just fine, ON when it is set to, OFF when it was supposed to.
(Maybe it's goofy bud?)
Dave
Dave Andreae
Parallax Tech Support·
goofybud16
