Source for solid-core ribbon?
Oldbitcollector (Jeff)
Does anyone have a source for solid-core ribbon cable?
something about the gage of breadboard wire would be perfect, multicolor would be a bonus.
Thanks!
OBC
New to the Propeller?
Thanks!
OBC
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=90101/20%20100-ND
·they have it from 20 to 100 conductors.
You could use standard 50-mil stranded ribbon cable, terminated with an IDC DIP connector, and plugged into a wirewrap DIP socket. That would allow you to bridge the proto board's center gap and use all the conductors individually.
Another alternative is a ribbon cable terminated with female header connectors. Header pins will fit both the cable connector and the breadboard. Samtec carries cable assemblies with single-row header connectors attached. You'd be using just every other cable conductor, which would also be the case with a dual-row header connector, since the spacing between the rows can't bridge the proto board's center separator. However, with the dual-row header connector, you could also use dual-row headers plugged into one side of the proto boards to double the current capacity of the cable.
@Phil: Good suggestion, but not the look I want with this project (ProtoBlade)
Anyone else?
OBC
How many conductors are you looking for?
Beau Schwabe
IC Layout Engineer
Ideal... 10.. This way I can wire an entire I/O side of a Protoboard to "in-row" connections.
OBC
I bent the wires at right angles and used a pair of solderless breadboards to get the spacing right and stretch them tight, then applied the tape to the top and pulled the wires out to make the final wrap. A fingernail along each interwire gap helped to seal the deal. It seems to maintain its integrity despite bending and twisting.
Beau Schwabe
IC Layout Engineer
http://www.allelectronics.com/make-a-store/item/RJ-310/10-CONDUCTOR-RIBBON-JUMPER-CABLE-3-/1.html
You, Sir... are a genius!
Bill
Then you'd use silvery duct tape...
Don't visit my new website...
What a great alternative! Absolutely great.
Thank you,
DJ
You've given me a couple ideas to expand on this idea a little..
OBC
LOL... I like to think this forum is the sort of place McGyver peruses from time to time for ideas.
@OBC, a check of the local electronics disposal store (rockby) led me to this Tyco part - FSN21A. Seems to be a solid core ribbon at 0.1" pitch...
datasheet.octopart.com/FSN-21A-10-Tyco-Electronics-datasheet-505599.pdf
