Source for solid-core ribbon? — Parallax Forums
edited 2010-01-07 20:47 in General Discussion
Does anyone have a source for solid-core ribbon cable?
something about the gage of breadboard wire would be perfect, multicolor would be a bonus.
Thanks!
OBC
New to the Propeller?
  • kf4ixmkf4ixm Posts: 529
    edited 2010-01-06 16:03
    found this at digikey, grey jacket only though...
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=90101/20%20100-ND
    ·they have it from 20 to 100 conductors.
  • wjsteelewjsteele Posts: 697
    edited 2010-01-06 16:53
    Of course, at $664.25 for a minimum order of 3... it's a little expensive for a hobbiest. :-]
    edited 2010-01-06 19:21
    OBC,
    You could use standard 50-mil stranded ribbon cable, terminated with an IDC DIP connector, and plugged into a wirewrap DIP socket. That would allow you to bridge the proto board's center gap and use all the conductors individually.
    Another alternative is a ribbon cable terminated with female header connectors. Header pins will fit both the cable connector and the breadboard. Samtec carries cable assemblies with single-row header connectors attached. You'd be using just every other cable conductor, which would also be the case with a dual-row header connector, since the spacing between the rows can't bridge the proto board's center separator. However, with the dual-row header connector, you could also use dual-row headers plugged into one side of the proto boards to double the current capacity of the cable.
    edited 2010-01-06 20:37
    $6.64 a foot! Icarumba! Although I might pay that if I could buy 24" at a time.
    @Phil: Good suggestion, but not the look I want with this project (ProtoBlade)
    Anyone else?
    OBC
    edited 2010-01-06 21:03
    Well, there's always solder-tab-to-solder-tab flex cable: dkc3.digikey.com/PDF/US2010/P0074.pdf. The tabs may be a little on the short side, though.
    edited 2010-01-06 21:05
    Oldbitcollector,
    How many conductors are you looking for?
    Beau Schwabe
    IC Layout Engineer
    edited 2010-01-06 22:45
    Beau Schwabe (Parallax) said...
    Oldbitcollector,
    Ideal... 10.. This way I can wire an entire I/O side of a Protoboard to "in-row" connections.
    OBC
    edited 2010-01-07 04:44
    It's easy enough to fabricate your own color-coded ribbon cable from solid jumper wires and transparent packaging tape:
    I bent the wires at right angles and used a pair of solderless breadboards to get the spacing right and stretch them tight, then applied the tape to the top and pulled the wires out to make the final wrap. A fingernail along each interwire gap helped to seal the deal. It seems to maintain its integrity despite bending and twisting.
    613 x 363 - 29K
    edited 2010-01-07 06:09
    Nice Phil!
    Beau Schwabe
    IC Layout Engineer
  • TubularTubular Posts: 4,740
    edited 2010-01-07 11:08
    That is just so McGyver. I love it...
    Phil Pilgrim (PhiPi) said...
    edited 2010-01-07 12:08
    Only 3" long but seems cheap enough.
    http://www.allelectronics.com/make-a-store/item/RJ-310/10-CONDUCTOR-RIBBON-JUMPER-CABLE-3-/1.html
    edited 2010-01-07 14:08
    It's easy enough to fabricate your own color-coded ribbon...
    You, Sir... are a genius!
    Bill
    edited 2010-01-07 14:28
    Tubular said...
    Nope...
    Then you'd use silvery duct tape...
    Don't visit my new website...
    edited 2010-01-07 16:28
    Mr. Pilgrim,
    What a great alternative! Absolutely great.
    Thank you,
    DJ
    edited 2010-01-07 17:05
    Not bad.. Not bad at all..
    You've given me a couple ideas to expand on this idea a little..
    OBC
    Gadgetman said...
    Nope...
    LOL... I like to think this forum is the sort of place McGyver peruses from time to time for ideas.
    @OBC, a check of the local electronics disposal store (rockby) led me to this Tyco part - FSN21A. Seems to be a solid core ribbon at 0.1" pitch...
    datasheet.octopart.com/FSN-21A-10-Tyco-Electronics-datasheet-505599.pdf
