Request Help MSR1 Propeller Board + 2 Sabertooth Motor Controllers + 1
My son and I have built a fully customized robot using
(1) MSR1 Robot Contol Board
(2) Sabertooth Motor Controllers
(4) DC Motors
(1) Vex Receiver & Transmitter (6 Channel)
We have attached:
- Schematic of interface for our Vex Receiver and Motor Controllers to the Propeller MSR1 Robot Control Board
- (3) Spin Objects
-- VexDemux Call··· (Top Oject)
-- Vex Demux········ (Demux the PPM to PWM ~ I think)
-- VexMotorEngine··(Intended to communicate PWM to Sabertooth MC's)
We are fairly new at this and have dove in head first - can anyone help us with the SPIN Objects.
They are all taken from past Propeller forum and·object exchange efforts.· We have done the initial modifications to the first two files and are more·stumped on the third,,, as well as the others.
Any help is greatly appreciated.
Thanks in advance.
(4) DC Motors
We have attached:
- (3) Spin Objects
Thanks in advance.
You will need to use a different object for you motors though. This object (obex.parallax.com/objects/51/) will do what you need. You will also need to connect the ground wire for both channels of the motor controller to the propeller board (I didn't do it on a board I was using and it took us several hours to figure out why the motors weren't running properly).
You will need some code in VexDemux Call.spin something like this to get it all to work properly.
Thank you so much for the reply - very much appreciated.
We will give this a try and let you know how it goes.
