ProtoBlade - Add 512KB SRAM & SD to make your prop protoboard a RamBlade/TriBla — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2010-01-15 17:14 in Propeller 1
OBC (oldbitcollector) asked me about making·an equivalent RamBlade circuit using·the Prop ProtoBoard.
There are a few reasons why this is not really possible, so here is an alternative. It will not run as fast as a RamBlade because I cannot use the same address and data pins as on my RamBlade. The circuit is more like the TriBlade (Blade #2 section) which is what we have been developing ZiCog & CPM on. It is bigger than a RamBlade of course and you have to solder and wire it yourself.
You cannot have anything else wired on the ProtoBoard without potential conflicts. Specifically this means you cannot have the additional resistors fitted for the VGA, Keyboard or mouse.
The only connections possible with this circuit is via the two programming pins P30 & P31. This may be...
  • Serial communications using the 2-pins
    • Non-USB ProtoBoard:·optionally via a propplug
    • USB ProtoBoard: via the USB connection (it can be cut and optional links fitted to seperate the PropPlug section)
  • OR
    • Keyboard using the 1-pin keyboard circuit
    • Video (TV) composite using the 1-pin video circuit - monochrome (black & white) only
What you require...
  • SRAM AS6C4008-55PCN 512KB 55ns DIP32 from Future Electronics
  • SD or microSD socket or SD to microSD adapter
  • 4 x 10K (optional)
  • 2·x 0.1uF mono capacitors
  • 1 x 1uF 6V (or > 6V) Tantalum capacitor
  • SD or microSD card
I have added 4 x 10K (optional) to the parts list. I had intended to use the existing 4 x 10K pullups (with links) on the PS2 keyboard and mouse connectors. However, I think it would be better to add these resistors seperately and keep the PS2 Keyboard circuit (plus additions) for the 1-pin keyboard circuit. Therefore, I will change the microSD pins DO, CLK, DI from P24, P25, P26 to P0, P1, P2. Updated circuit to be posted soon.
Note the 1-pin video will be connected to P30 and the 1-pin keyboard will be connected to P31, both via links (not as the schematic shows).
If you want to use the·1-pin video and 1-pin keyboard circuits then you will also require...
  • 1 x PS2 Socket Digikey CP-4060-ND
  • 1 x 270R
  • 3 x 10K
  • 1 x 15K
  • 1 x 1500pF·capacitor (ceramic or greencap)
  • option extras 1 x 120R, 1 x 180R, 1 x 470pF
  • RCA-RCA·(yellow preferred) video cable - cutoff 1 end
  • Optional 2-pin plug and socket for RCA video cable - else solder cable to pcb directly
The schematic of the 1-pin video and keyboard circuits are also attached cool.gif
Post Edited (Cluso99) : 1/6/2010 3:37:06 PM GMT
