Possible shortages?
Hi,
My group and I are using the BSSX with the Super Stamp Carrier. We were trying to control the Boe-Bot with a PS2 Controller and Wireless Force 2 Controller, which I had gotten to work. However, without my knowledge, one person was playing around with a LED, putting it against random pins that were previously soldered into the board. For some reason, the Force Controller and the power supply (which our teacher is making us use instead of batteries) no longer work.
Can anyone tell me what happened? Also, is there anything that I can do to fix them?
Thanks [noparse]:)[/noparse] I greatly appreciate your answers [noparse]:)[/noparse]
*Before hooking up power supply set the voltage to the voltage of the rail and current to 0. Slowly ramp current up until you find hot spot or the short bursts.
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
Are you describing the procedure for a power supply for a computer? I meant the outlet to Boe-Bot DC power. (sorry, I don't know much about electronics
I do not have a boe-bot or know anything about it but sounds like you may have a short. that can be found out easily with a multimeter. However finding and fixing shorts can be dificult and time consuming. This method works quickly.
