Stingray Battery Adapters — Parallax Forums
Roy ElthamRoy Eltham Posts: 3,000
edited 2009-12-21 02:36 in Robotics
Attached is a picture of a couple of adapters I made to connect regular R/C batteries with Tamiya connectors to the Stingray.
THe Mouser part numbers for the pieces needed (minus the wire) are:
538-35728-0201·- SKT 14-20 AWG - $0.07 each
538-35143-0201·- 2 POS PLUG HOUSING·- $0.32 each
538-50217-8100 - SOCKET 18-24AWG BULK - $0.26 each
538-35156-0200 - POSITIVE LKG HSG 2P - $0.14 each
On the 2 to 1 adapter, fitting the 2 wires into the crimp spot on them was tight. I ended up soldering them in place since the crimping wasn't secure enough. That wouldn't be a problem with higher guage wire, but I used what I had.
Check out the Propeller Wiki·and contribute if you can.
  • GeorgeCollinsGeorgeCollins Posts: 132
    edited 2009-12-19 23:56
    I was doing almost the exact same thing this week, but with smaller battery connectors, not Tamiyas. I also ended up using a little solder because the crimp did not seem secure enough on the light gauge wire I was using. The jury is out for me, but I think I would prefer to have screw terminals on this board to the plugs. Screw terminals do fail sometimes, but they are lot easier to work with.
    My Robots
  • SRLMSRLM Posts: 5,045
    For mine, instead of molex connectors I used a male (female? The side that is on the end of the wire) barrel jack connector. It seems to work okay so far. Thanks for the part numbers.
    Powered by enthusiasm
