Stingray Battery Adapters
Roy Eltham
Attached is a picture of a couple of adapters I made to connect regular R/C batteries with Tamiya connectors to the Stingray.
THe Mouser part numbers for the pieces needed (minus the wire) are:
538-35728-0201·- SKT 14-20 AWG - $0.07 each
538-35143-0201·- 2 POS PLUG HOUSING·- $0.32 each
538-50217-8100 - SOCKET 18-24AWG BULK - $0.26 each
538-35156-0200 - POSITIVE LKG HSG 2P - $0.14 each
On the 2 to 1 adapter, fitting the 2 wires into the crimp spot on them was tight. I ended up soldering them in place since the crimping wasn't secure enough. That wouldn't be a problem with higher guage wire, but I used what I had.
Check out the Propeller Wiki·and contribute if you can.
My Robots
Powered by enthusiasm
