FTDI help
Can someone point me to the correct schematic to use with the propeller? Here is the group of schematic that I am guessing I am supposed to use: here. Or maybe someone has a more custom/better one specifically designed for the prop?
A while back (a few weeks ago), I remember a thread mentioning how to stop the propeller from resetting (from the plug booting up momentarily) when the prop plug is left connected to the propeller but not any USB power. Does this occur if the FTDI chip is being powered on the same power as the prop?
Edit: removed comment about something I misread.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Post Edited (Bobb Fwed) : 12/16/2009 5:09:31 PM GMT
Some of my objects:
Some of my objects:
Nyamekye,
http://forums.parallax.com/showthread.php?p=847290
Some of my objects:
Some of my objects:
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Some of my objects:
Let me know if anything seems wrong. The AVCC wiring seems to be the only suggested way to wire it (according to the datasheet).
It is somewhat of a hybrid between the two previously mentioned schematics.
EDIT: change on schematic: IOVCC now connect to same 3.3V circuit as Prop instead of FT232's internal 3.3V regulator.
Some of my objects:
Post Edited (Bobb Fwed) : 12/18/2009 11:37:27 PM GMT
I am not sure why you are using a 74LVC07 - care to explain?
I note you have connected the FTDI reset to the USB 5V - presume this is to do with the reset problem if unplugged?
The reset pin being pulled up is required on the FTDI chip I have in the schematic. But after further reading it appears that chip does not have an internal oscillator. An oscillator (or XTAL) is required to function with USB. So I have reluctantly switched to the RL which has all the necessary things, and doesn't require the reset pull up or the AVCC and a couple other things.
Thank you for the info, but I had also figured out I needed a type-B USB in the last few hours.
Some of my objects:
You don't need to remove or comment out all the serial code. Setting the serial TX/RX pins to a couple of unused pins seem to work to me.
James Ronald
My Robots
