FTDI help — Parallax Forums
FTDI help
Bobb FwedBobb Fwed Posts: 1,119
edited 2009-12-19 16:46 in Propeller 1
Can someone point me to the correct schematic to use with the propeller? Here is the group of schematic that I am guessing I am supposed to use: here. Or maybe someone has a more custom/better one specifically designed for the prop?
A while back (a few weeks ago), I remember a thread mentioning how to stop the propeller from resetting (from the plug booting up momentarily) when the prop plug is left connected to the propeller but not any USB power. Does this occur if the FTDI chip is being powered on the same power as the prop?
Edit: removed comment about something I misread.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Post Edited (Bobb Fwed) : 12/16/2009 5:09:31 PM GMT
