Vdd during programming
Recently I bought a small bunch of 28-pin DIP SX chips from a major supplier and found that a couple of them won't program (using the SX Key) with Vdd at 3 volts. They will program with Vdd around 5 volts and they seem to run ok after programming when Vdd is 3 volts. All the previous chips I've used program fine when Vdd is 3 volts as do some of the chips in this batch. Is this a common problem?
Katie
Katie
I assume you have the USB version of the SX-Key ? The serial version does need 5.0V to program.
Bean.
1st rule of finance...Don't lose money.
Never be ashamed of making an honest·profit.
Live within your means...Make do, or do without.
Yes, I'm using the USB version of the SX-Key.
Hopefully it's just these couple of bad chips, I've got more coming soon from this same supplier and will test them when they arrive.
Thanks again,
Katie
