Propeller Chip Eagle part
Does anyone know the Eagle liberary part for the Propeller Chip?
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
google is your friend!
Coley
PropGFX - The home of the Hybrid Development System and PropGFX Lite
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
When I lay down the wires they do not line up with the pins on the smaller packages. What do I do?
www.smarthome.viviti.com/build
Caps and resistors are in the RCL menu. Try any of the caps first, scroll through them and the first half are through hole the second half are surface mount. I tend to find the right one, check it is right on the board and against the part number, and then copy it for all the components needed and change the value.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
by the way library on eagle site is wrong for qfn. here is correct library
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
It's Only A Stupid Question If You Have Not Googled It First!!
Cool beans! any hope on seeing a 'pre-release' before christmas?
-- David Carrier
