Propeller Chip Eagle part — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2009-12-16 04:26 in Propeller 1
Does anyone know the Eagle liberary part for the Propeller Chip?
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
  • ColeyColey Posts: 1,130
    edited 2009-09-23 18:19
    tp.cadsoft.de/eagle/userfiles/libraries/parallax_propeller.lbr
    google is your friend!
    PropGFX - The home of the Hybrid Development System and PropGFX Lite
  • whickerwhicker Posts: 749
    Now would probably be a good time to learn how to create a custom part.
    edited 2009-09-23 18:21
    I found it myself! Thanks for the help!
  • AleAle Posts: 2,363
    edited 2009-09-23 18:44
    You add name and value using ">NAME" and ">VALUE" as texts (so you add those texts where you want that info displayed) in the Name, Value or tName/bName, tValues/bValues layers. Do no forget them so the name (i.e. C10) and value (100nF) show in the schematic and PCB layout.
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-09-23 23:40
    Okey, wait.. now I have another problem.....
    When I lay down the wires they do not line up with the pins on the smaller packages. What do I do?
    edited 2009-09-23 23:43
    If the wires don't line up, make the grid setting smaller. View/Grid. Defaults to 0.1" I think, which is too coarse for smaller package sizes. Don't make it too fine though, as it increases the autorouter time.
    www.smarthome.viviti.com/build
    edited 2009-09-24 00:03
    Thanks! That worked! Also, is there a standard SMD resistor/capacitor size?
    edited 2009-09-24 01:36
    Yes, all the standard sizes are there but you have to find them in amongst the non standard ones!
    Caps and resistors are in the RCL menu. Try any of the caps first, scroll through them and the first half are through hole the second half are surface mount. I tend to find the right one, check it is right on the board and against the part number, and then copy it for all the components needed and change the value.
    edited 2009-09-24 07:55
    Parallax and I think Brian Carpenter are working on an EAGLE library, an official library, for all of the Parallax parts. Perhaps he can post what work has been done for the Propeller chip.
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
    edited 2009-09-24 17:36
    try looking under rcl for 0603. most of the resisters i sent you are that size.
    by the way library on eagle site is wrong for qfn. here is correct library
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
    edited 2009-09-24 20:44
    Thanks! What is the SMD EEPROM (from parallax) EAGLE part?
    edited 2009-09-24 20:46
    you can easily build any part from its data sheet. if you have the part number search for it on digikey you will easily find the datasheet on there.
    edited 2009-09-25 00:18
    There are a few eeproms. I tried searching for 'eeprom' and lots of DIP parts came up, but there is a SMD one about 2/3 down the list, in the microchip library under 24LC*. Searching Eagle libraries can be a bit tricky - if you have a moment just mindlessly scroll through everything in the library as it is amazing what is there.
    edited 2009-09-25 18:00
    I am done with version one of my device! Thanks for the help, because I'll most likely need more. smile.gif See the Speech Module thread.
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2009-09-25 18:23
    There will soon be a sticky with Parallax certified correct eagle parts.
    It's Only A Stupid Question If You Have Not Googled It First!!
  • OakGraphicsOakGraphics Posts: 202
    edited 2009-12-15 17:05
    Brian Carpenter said...
    Cool beans! any hope on seeing a 'pre-release' before christmas?
  • David CarrierDavid Carrier Posts: 294
    edited 2009-12-16 01:51
    This thread has been added to the Propeller: Getting Started and Key Thread Index.
    -- David Carrier
  • Sal AmmoniacSal Ammoniac Posts: 213
    If you haven't already, check out the SparkFun Eagle library. It has many components difficult to find elsewhere, including the Xbee, and many (but not all) of the parts sold by SparkFun cross referenced by the SparkFun part number.
