Free 4-layer PCB software?
We can probably do our project with two layers, but I'd rather not cause it'd get bigger than we want. This is a core processing unit about the size of a Basic Stamp, modelled after an Arduino Nano.
However, the free version of Eagle (which our team lead is familiar with) and the free version of DipTrace (which I have used) both only can do two layers. Is there any good PCB software out there that can do 4 layers?
Rafael
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
KJ6AWU
Rafael
KJ6AWU
Duffer
Raf
KJ6AWU
Leon
Amateur radio callsign: G1HSM
but maybe you can use 2-layer board software to make 2 or 3 thin boards with the same holes and then build on
all of them stacked together. It seems like the most obvious way to me to manufacture one at this moment.
Another idea maybe having 2 boards stacked with pins and headers. I can't imagine why anyone would think
they need 4 layers while using a free trial version of board software, unless it's stuffed with BGAs or has
...What just happened? An annoying bug. Sorry.This keeps
happening and I can’t see what I’m typing very well.I don’t
see anything on here about changing to the ugliest font in
the universe but I know it always goes back to normal only as
soon as I finish typing and never before or after.
Nice font btw [noparse];)[/noparse]
Raf
KJ6AWU
There are some 'hidden' problems with using PCB Artist though. It is a pretty unstable piece of software (although it has been getting better with the later versions). It can crash randomly, so save very often. The built in libraries are also much less reliable than Eagle's (in fact, there were a number of parts totally wrong in the libraries, which we were lucky to catch before manufacturing). If you do choose to use PCB Artist, I would recommend you make every part by hand, except for maybe resistors and capacitors.
http://www.freepcb.com/
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
