Free 4-layer PCB software? — Parallax Forums
FlyingFishFingerFlyingFishFinger Posts: 461
edited 2009-12-15 18:08 in General Discussion
We can probably do our project with two layers, but I'd rather not cause it'd get bigger than we want. This is a core processing unit about the size of a Basic Stamp, modelled after an Arduino Nano.
However, the free version of Eagle (which our team lead is familiar with) and the free version of DipTrace (which I have used) both only can do two layers. Is there any good PCB software out there that can do 4 layers?
Rafael
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
KJ6AWU
  • DufferDuffer Posts: 374
    edited 2009-12-14 18:35
    ExpressPCB: http://www.expresspcb.com/·can create both 2-layer and 4-layer boards. It's free, but the files created are only usable for board fabrication·by ExpressPCB and cannot be used by other PCB manufacturers.
    Duffer
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2009-12-14 18:36
    Yeah I've played with that before, not such a fan. Our team has a deal with AC circuits though, we get free fab. So it'd be nice to be able to send designs to them...
    Raf
    KJ6AWU
  • LeonLeon Posts: 7,620
    edited 2009-12-14 19:02
    The Advanced Circuits software is nicer. It's actually a special version of Number One Systems' Easy-PC. I think that they give you the Gerber's etc. if you order a second board.
    Leon
    Amateur radio callsign: G1HSM
  • VIRANDVIRAND Posts: 656
    edited 2009-12-14 19:14
    This might be a dumb idea because I thought about, but never ever actually needed a 4 layer board,
    but maybe you can use 2-layer board software to make 2 or 3 thin boards with the same holes and then build on
    all of them stacked together. It seems like the most obvious way to me to manufacture one at this moment.
    Another idea maybe having 2 boards stacked with pins and headers. I can't imagine why anyone would think
    they need 4 layers while using a free trial version of board software, unless it's stuffed with BGAs or has
    ...What just happened? An annoying bug. Sorry.This keeps
    happening and I can’t see what I’m typing very well.I don’t
    see anything on here about changing to the ugliest font in
    the universe but I know it always goes back to normal only as
    soon as I finish typing and never before or after.
    edited 2009-12-14 19:21
    Well I don't know if we NEED 4 layers to make it work, but seeing as the Arduino we're basing the design off of needed 4 layers to fit in the footprint... we're adding / removing a few components but it's essentially the same thing. We're trying not to increase the footprint too much because it's supposed to be quick-swappable CPU unit on our boards..
    Nice font btw [noparse];)[/noparse]
    Raf
    KJ6AWU
  • Harrison.Harrison. Posts: 484
    edited 2009-12-14 22:46
    I would definitely use Advanced Circuit's PCB Artist. It's pretty good when compared to other free packages handed out by PCB manufacturers (the DRC and consistency check features are excellent). I've used it during a class project and found it to be much better than ExpressPCB.
    There are some 'hidden' problems with using PCB Artist though. It is a pretty unstable piece of software (although it has been getting better with the later versions). It can crash randomly, so save very often. The built in libraries are also much less reliable than Eagle's (in fact, there were a number of parts totally wrong in the libraries, which we were lucky to catch before manufacturing). If you do choose to use PCB Artist, I would recommend you make every part by hand, except for maybe resistors and capacitors.
  • RickBRickB Posts: 395
    edited 2009-12-15 16:09
    Free PCB. 16 layers
    http://www.freepcb.com/
    use eagle to design 2. 2layer boards. then rename the gerber files on the 1 board 2 be the inner 2 layers. this will work if all wholes and vias are in same spot
    24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
