edible wire
I am trying to figure out a way to run electrical wires through food. must be non toxic and edible. so far only idea is use licorice and salt water. any other ideas?
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
it May be possable but I need to know what kind of power and siganal we are dealing with and also what kind of impedance.
( this reminds me of the time I wanted to invent a spandex based extension cord ..)
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
How do you plan to connect to the conductors? You don't want most metals directly in contact with the food.
I've often wondered how conductive those silver balls used for cake decorating are? Could you string those together?
Need to know what you're trying to 'light' ... how many volts, current etc
This has got to be one of the more unusual requests to appear in the forum. Enquiring Minds Want to Know TM: what is your application?
Led lighting in gingerbread house.
Last time I baked cookies with LEDs, gallium arsenide was still listed as a poison. Also, they break your teeth when you bite into one too hard. So tell your guests to bite softly. In any case, if you must, how about trying graphite? It's used in food grade lubricants and by itself will conduct electricity. Note that amorphous carbon will NOT conduct, so don't try burning your gingerbread house just to make it conductive - it won't work.
www.tribology.com/food_bht.htm
Post Edited (Mike Green) : 12/14/2009 3:55:57 AM GMT
Leave the LEDs cemented to the base where nobody could accidently eat them, then pipe the light up to little candies that will blink and glow.
Wintergreen oil will fluoresce in UV, so... hmmm, on second thought, better not use UV. You don't want your guests mutating before your eyes.
As for any kind of foil, I'm not sure how galvanic it will get with dental fillings and such.
LOL
Actually ice is a bad conductor, and salt water when frozen, tends to exclude the salts so the frozen sea water doesn't conduct too well, either.
mctrivia,
just curious: were you one of those kids in school that, when you made a model volcano for earth science class, had it erupt with real lava?
Yes, I thought so.
LOL
i know for a fact gold foil will work. very thin can be easily biten through and will conduct.
as for real lava nope but I did make models with little lights.
Sounds like a cool idea!
Actually, if I remember correctly, water ice at ~2 Gigapascals will conduct electricity quite well. So technically your idea could work for electrons, too.
http://www.bareconductive.com/home.html
Duffer
Peter....
LOL
How much current?
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
Duffer just because something is safe for external application does not mean it is safe to ingest. But that is pretty cool.
Ice will not work because it will melt. Need something that can last at least a week but not likely any longer.
Peter
LOL
candy.about.com/od/gumgelatinbasedcandy/r/gummyworms.htm
Instead of coloring, I guess you could add a transparent flavor like pineapple or lemon or butyric acid.
There are many foods that could be considered editable by some, but completely unpalatable to others.
A Fire-Fly is probably editable, but not very palatable.
Beau Schwabe
IC Layout Engineer
www.whitakercenter.org/pdf/Grades%209-12/9-12%20Color%20and%20Light/Gelatin%20Fiber%20Post.pdf
www.math.unl.edu/~jump/Center1/Labs/foodscienceworkshop.pdf
How about IRON, yes iron.
This is a needed element and it is found in just about every vitamin out there.
Made into a paste with some base material, like Angle hair pasta
Post Edited ($WMc%) : 12/14/2009 7:34:47 AM GMT
Not sure if the leds are a good idea though, especially if young children are going to eat it unless the leds are in enclosures too big to get in young mouths.
Hemochromatosis. You really don't want it.
If you always do what you always did, you always get what you always got.
Graphite: A 5" pencil lead (Dixon Ticonderoga #2, soft)·measures just under 13 Ohms.
Also, food grade oils containing graphite: http://www.tribology.com/food_bht.htm
and: https://www.keytite.com/
Duffer
Post Edited (Duffer) : 12/14/2009 4:11:52 PM GMT
