Connecting the Propeller Plug to the Fonera 2100
Okay, really basic stuff here, but how do I connect my Propeller Plug USB adaptor to the serial header pins on a Fonera 2100? I've attached a diagram culled from the InterWebs that purports to document the pinout. I can guess what to do with TX/RX, but should the Propeller Plug's VSS be connected to GND or 3.3VCC? And do I just ignore NRES?
TIA!
TIA!
If you always do what you always did, you always get what you always got.
