miniSD breakout PCB for Propeller Proto Board — Parallax Forums
LeonLeon Posts: 7,620
edited 2009-12-12 00:01 in Robotics
I've designed a little breakout board for a miniSD card and interfaced it to a Propeller Proto Board. It runs the Rokicki and Dummer fsrw23 test software, so it's working OK. If anyone wants to make one I've attached the files; the zip file contains the artwork and schematic PDFs.
It uses the (rather expensive) Yamaichi NMS011-2000-1 connector, RS Stock No. 493-2052.
The 0.64 mm square pins plug into a six-way socket on the Proto Board.
Drills are 0.7 mm, 0.9 mm, 1.3 mm and 1.5 mm. It should be obvious which ones are which.
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 12/8/2009 4:37:06 PM GMT
  • Rob7Rob7 Posts: 275
    edited 2009-12-10 14:51
    Cool Leon,
    I love playing with SD cards !
  • LeonLeon Posts: 7,620
    edited 2009-12-10 23:28
    I never had anything to do with them until a few weeks ago (apart from plugging them into a camera), when I was doing some work on a Propeller data logger for a client. He'd already had the PCB designed so it was just the software that I had to do, but I felt I ought to learn something about the hardware as well. I'll be transferring it to a different system (not a Propeller) and writing software for it from scratch, so it's nice to know that it's working.
    Leon
    Post Edited (Leon) : 12/10/2009 11:35:22 PM GMT
  • ManetherenManetheren Posts: 117
    edited 2009-12-11 21:43
    Any microsd interface hardware??
    Tia'Shar Manetheren
    edited 2009-12-11 22:04
    I actually used a microSD card in an miniSD adapter for testing my hardware. If you need something with a microSD socket I could do it, but do you really need it?
    Leon
    prob not. Thanks, cool project. Always need the storage.
    Tia'Shar Manetheren
