miniSD breakout PCB for Propeller Proto Board
I've designed a little breakout board for a miniSD card and interfaced it to a Propeller Proto Board. It runs the Rokicki and Dummer fsrw23 test software, so it's working OK. If anyone wants to make one I've attached the files; the zip file contains the artwork and schematic PDFs.
It uses the (rather expensive) Yamaichi NMS011-2000-1 connector, RS Stock No. 493-2052.
The 0.64 mm square pins plug into a six-way socket on the Proto Board.
Drills are 0.7 mm, 0.9 mm, 1.3 mm and 1.5 mm. It should be obvious which ones are which.
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 12/8/2009 4:37:06 PM GMT
Leon
I love playing with SD cards !
Leon
Post Edited (Leon) : 12/10/2009 11:35:22 PM GMT
Tia'Shar Manetheren
Leon
Tia'Shar Manetheren
