Prop-o-scope
Has anyone had any experience in creating a rudimentary oscilloscope using a propeller? I'm trying to measure 36-56kHz signals through an infrared phototransistor (recording remote control signals) so I don't need an oscilloscope that is hugely powerful. A friend of mine has one of the Saleae Logic Probes whick works nicely but I don't want to have to keep bugging him to borrow it.
Anyone have ideas? I merely want to be able to read the signal (pulse durations, etc) in order to recreate them later. Simple enough, but I can't get it to work.
Who are you, and why are you reading my signature?
http://www.parallax.com/Store/Microcontrollers/PropellerTools/tabid/143/ProductID/586/List/0/Default.aspx?SortField=ProductName,ProductName
or Prop specific development, ViewPort:
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/Viewport/List/0/SortField/4/ProductID/546/Default.aspx
Ether way a cool bench tool designed around the propeller.
Propeller Logic Analyzer
http://forums.parallax.com/showthread.php?p=606048
OBC
New to the Propeller?
The Parallax PropScope is open-sourced hardware (Creative Commons). Have it it! You can even build your own.
The Propeller firmware is not released, but you're welcome to our circuit.
Sincerely,
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
http://forums.parallax.com/showthread.php?p=788230
Propalyzer is not a real-time oscope, but it is quite useful.
Post Edited (jazzed) : 12/10/2009 7:34:16 AM GMT
some time ago I experimented with the combination of ADC820 and the propeller to make a standalone dual channel DSO. You might have a look at PROPSCOPE820:
http://forums.parallax.com/showthread.php?p=622252
The configuration should have enough performance for this.
Good luck
Christof
