Prop-o-scope — Parallax Forums
Prop-o-scope
CumQuaTCumQuaT Posts: 156
edited 2009-12-10 13:24 in Propeller 1
Has anyone had any experience in creating a rudimentary oscilloscope using a propeller? I'm trying to measure 36-56kHz signals through an infrared phototransistor (recording remote control signals) so I don't need an oscilloscope that is hugely powerful. A friend of mine has one of the Saleae Logic Probes whick works nicely but I don't want to have to keep bugging him to borrow it.
Anyone have ideas? I merely want to be able to read the signal (pulse durations, etc) in order to recreate them later. Simple enough, but I can't get it to work.
Who are you, and why are you reading my signature?
  • mikedivmikediv Posts: 825
    edited 2009-12-10 01:59
    CumQuat I do not know of a prop circuit but if you are interested I have a design for a PIC chip its actually pretty powerful the cost for the whole thing is around 30 dollars the software is free I have not built mine yet but I am in the process of wire wrapping a unit to see how it works if you have an LCD it will be even cheaper since the screen was the most expensive part, also Ebay has a finished product thats pretty nice it basically a big LCD screen that is the whole oscilloscope they cost 50 dollars but its a very nice unit and comes with a probe these are both single channel
  • CumQuaTCumQuaT Posts: 156
    edited 2009-12-10 02:02
    Sounds fantastic. I predominantly work with PICs and have space screens all over the place.
  • hover1hover1 Posts: 1,929
    edited 2009-12-10 02:03
    Ahh, PropScope:
    http://www.parallax.com/Store/Microcontrollers/PropellerTools/tabid/143/ProductID/586/List/0/Default.aspx?SortField=ProductName,ProductName
    or Prop specific development, ViewPort:
    http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/Viewport/List/0/SortField/4/ProductID/546/Default.aspx
    CumQuaT said...
    edited 2009-12-10 02:05
    Yeah, that's US$250 for overkill. I'm only after a sampling of up to a 56kHz wave with a US$7 prop.
    edited 2009-12-10 02:11
    This isn't a Propscope but maybe it's a starting point software-wise?
    Ether way a cool bench tool designed around the propeller.
    Propeller Logic Analyzer
    http://forums.parallax.com/showthread.php?p=606048
    OBC
    New to the Propeller?
    edited 2009-12-10 02:13
    Very interesting. This looks kinda of similar to the Saleae Logic Probe. Cheers for the link!
    edited 2009-12-10 02:43
    CumQuaT,
    The Parallax PropScope is open-sourced hardware (Creative Commons). Have it it! You can even build your own.
    The Propeller firmware is not released, but you're welcome to our circuit.
    Sincerely,
    edited 2009-12-10 05:00
    As awesome as it is that the hardware is open-source (I'm all for that) my expertise with programming propellors is quite limited, so without firmware it's no good to me [noparse]:([/noparse]
  • HannoHanno Posts: 1,130
    edited 2009-12-10 07:15
    Have a look at ViewPort, it includes several examples which do exactly what you want. You just need to add one line of code to your program to share the value of the phototransistor with ViewPort. ViewPort then gives you a fully function oscilloscope and logic analyzer to help you analyze your signals- including cursors, auto measurements, triggers, variable timescale- the works. Data can be exported to .txt, .csv, matlab, streamed to an ftp server, and more. 30 day free trial, license starts at $29.
    Hanno
    Co-author of the official Propeller Guide- available at Amazon
    Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
    12Blocks, the block-based programming environment (thread here)
    and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
  • jazzedjazzed Posts: 11,803
    edited 2009-12-10 07:28
    The Propalyzer thread offers an interesting alternative [noparse]:)[/noparse]
    http://forums.parallax.com/showthread.php?p=788230
    Propalyzer is not a real-time oscope, but it is quite useful.
    Post Edited (jazzed) : 12/10/2009 7:34:16 AM GMT
  • Christof Eb.Christof Eb. Posts: 1,431
    edited 2009-12-10 11:45
    some time ago I experimented with the combination of ADC820 and the propeller to make a standalone dual channel DSO. You might have a look at PROPSCOPE820:
    http://forums.parallax.com/showthread.php?p=622252
    The configuration should have enough performance for this.
    Good luck
    Christof
    Thanks for the ideas! Gives me some things to try on the weekend!
