Scribbler 2 (S2) Early Design Notes - a new Propeller robot — Parallax Forums
edited 2009-12-18 00:16 in Robotics
Hey there,
Word is out that we've got a new Scribbler in the works (S2), so I've written up some key features in the attached PDF. We're aiming for the same retail price ($99.99) and at this point I don't see why we wouldn't attain that goal. There's a lot of enthusiasm in Parallax about this new robot.
The release of S2 will also have impacts on our supply of original Scribblers.
You are invited to post whatever input you desire on this thread.
Sincerely,
Post Edited (Ken Gracey (Parallax)) : 12/2/2009 5:55:42 PM GMT
  • ericballericball Posts: 774
    edited 2009-11-25 16:55
    "What does S2 lose ..." not loose.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
    edited 2009-11-25 17:04
    You have August 2009 in the first part and August 2010 in the latter. I know you meant 2010 but it's confusing.
    Shawn Lowe
    When all else fails.....procrastinate!
    edited 2009-11-25 17:05
    Thanks - document repaired. August 2010 is our release date.
    Ken
  • AlsowolfmanAlsowolfman Posts: 65
    edited 2009-11-25 17:08
    This looks like a really good way to get people into the propeller, but have a few questions:
    Is it a quadrature encoder or a single channel encoder?
    Is it only programmed in serial, or is there a usb connection to, and if not is there an easy way to use the prop plug on it, or does one need a more generic usb to serial tool?
    edited 2009-11-25 17:16
    Optical single channel encoder. You'll know which direction based on the motor signals you provide.
    Serial only, because of legacy issues to support several key customers that use a significant volume of Scribblers with their add-ons. If you have a USB port only then you will use our USB to Serial converter.
  • BeanBean Posts: 8,129
    edited 2009-11-25 17:35
    Ken,
    It looks great.
    Any chance to get a schematic ? Or is that not finiallized yet ?
    Bean.
    Does that byte of memory hold "A", 65, $41 or %01000001 ?
    Yes it does...
    edited 2009-11-25 17:52
    Ken:
    Looks terrific, can't wait! Congrats on a fantastic job keeping the price at $99 with lots more capability. The built-in wheel encoders are DA BOMB! You didn't leave Whit and me any room for improvement. Now what will I do over New Year's break? Learn Spin, I suppose... [noparse]:)[/noparse] If you're looking for a Beta tester, I'm your Huckleberry!
    edited 2009-11-25 18:29
    Bean,
    The schematic is not yet final. The latest rev involves some simplifications and pin allocation jiggering to accommodate a new stall sensor. I think people will like the new design a lot! (I'm not the hardware engineer, BTW, but I've been consulting on the design and will be programming the low-level control object, along with the GUI code generation for the Prop.)
  • AleAle Posts: 2,363
    edited 2009-11-25 19:19
    ericball said...
    May it have been so loose that it detached itself and got lost ?
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
  • WhitWhit Posts: 4,194
    edited 2009-11-25 20:55
    Ken,
    This is great news! I am a bit sad to loose the old Scribber, but I understand. I (also) would love to test drive one of these. I can't wait to see how the Scribber 2 integrates with the GUI. That will make the transition for current Scribbler users a snap. I hope the GUI will take advantage of Scribbler 2 features while still working with the original.
    It sounds like you have addressed the concerns of current Scribbler users. Stronger motors and the encoders. Love the idea of bi-color LEDs. (That could be fun on the GUI as well). I hope there will be a bit more variation tolerated by the line following sensors. This robot has trememdous Educational potential!
    Some Questions:
    1. Will the Scribbler 2 come with the demo software or an improved version? This is a fantastic out-of the-box feature of the Scribbler and lets student play right away.
    2. Will the Observation Deck monitor the new encoders or external mic?
    3. Will provision be made for access to the updated hackers port through the Scribbler 2's body design (access openning of some sort).
    4. Will the GUI rollover into the Prop Tool? (Like the current Program Maker rolls over into the Stamp Editor)
    Some Comments:
    1. I hope things like all the pdf's for line following, bar codes, GUI and maybe a Spin (Yippee!) Programming Guide, internal pics and schematics are continued. That stuff is dynomite for using with students.
    2. I know you are working hard to make a $99 price point, but I would love a way to plug a Ping))) into a socket on the front of the Scribbler 2.
    Some Suggestions:
    1. You have got to get a Propeller Beanie on there somewhere!
    2. Perhaps the possibility of some add-ons - like a circular deck that would still let the pin port work, but would allow some experimental work space via connection to the hacker's port.
    3. Some mounting lugs on the outside of the body that would accept standard size screws. This could be used to mount things like a deck or hardware for a Ping))) mouting bracket or a display.
    4. I like retaining the Serial port for backward compatability and to allow the use of the IPRE Fluke. I would love a USB to Serial adapter in a single cable - perhaps a bit more ruggged.
    The funniest thing of all is that my 10 year old son was messing around with me about a couple of months ago. He comes up and says, "Hey Dad, Did you hear that they were making a Scribbler 2" (this is before I or he knew one was coming). "It has hands!"
    Just some thoughts... I know it will be great. Can't wait to hold one in my hot little hands! smilewinkgrin.gif
    Whit+
    Post Edited (Whit) : 11/25/2009 9:10:57 PM GMT
    edited 2009-11-25 21:03
    If the schematic is not final is there the possibility of adding an unpopulated header for the prop plug, or some ? That would effectively lower the cost 15 dollars as I would not need to buy the generic serial adapter.
    edited 2009-11-25 21:22
    First Hack Idea - Put the Scribbler 2 guts in a Scribbler body. Amaze people with your high performance Scribbler....
    Okay, maybe that is just a southern thing. cool.gif·
    Whit+
    edited 2009-11-25 21:29
    Whit,
    Some quesions I can address:
    "2. Will the Observation Deck monitor the new encoders or external mic?" 'Hadn't thought about that, so "maybe".
    "4. Will the GUI rollover into the Prop Tool? (Like the current Program Maker rolls over into the Stamp Editor)" Yes.
    The GUI will conform as closely as possible to that of the Scribbler 1 and will serve the same introductory-level function. Obviously, the wheel encoders and new stall sensor will be an intergral part of the low-level control software, so better directional and distance stability can be assured. My plan is to create an S2 object which will serve not only the GUI but also any Spin programmers who want to use it.
    edited 2009-11-25 21:59
    @ Phil - Sounds great!
    @ Ken - Remember the Beanie!
    Whit+
    400 x 215 - 146K
    edited 2009-11-25 23:18
    Phil Pilgrim (PhiPi) said...
    Phil,
    I think this is a great idea! It would be especially handy for robotics applications. As you know, I am a·major fan of the Scribbler Program Maker GUI. It made the old BS2 Scribbler instantly accessible for new students. I know the new version is going to make the Propeller Scribbler just as accessible. This will be wonderful.
    Whit+
    Post Edited (Whit) : 11/26/2009 2:17:37 AM GMT
  • Rob7Rob7 Posts: 275
    edited 2009-11-26 04:25
    This is something I have been waiting for.
    As a college student, not much money for a stingray.
    This will be just what the new propeller users need .
    Rob7
    edited 2009-11-26 07:19
    As long as this is becoming a wish-list-fest, I have just two words for you...
    FLUX CAPACITOR!
    edited 2009-11-26 14:16
    Nice - Doc erco!
    I guess my ideas on extra mounting spots were a bit wish listey, they are probably molding the body in the original Scribbler forms.
    Whit+
    Post Edited (Whit) : 11/26/2009 2:21:57 PM GMT
    114 x 118 - 4K
    edited 2009-11-29 20:45
    The incredible wheel encoder resolution makes more accurate dead reckoning a distinct possibility. Two thoughts:
    1) improve the wheel bushings and wheel/gearmotor fit for lower wear and reduced backlash.
    2) include some tunable PID routines in the GUI for accurate travel distance and turn measurement
    Can't wait to get my hands on one!
    edited 2009-11-30 02:02
    Another idea,
    I always thought that the pen port could be exploited as a place to mount Scribbler add-ons.
    An example would a post that could stand in the pen port for mounting a Ping))) on. It could have a servo as well to rotate the Ping))) also. Some external attachment point (both Ping))) and servo) for such items would be handy or a kit to make such attachments in a neat and simple way.
    Whit+
    edited 2009-11-30 02:45
    The pen port is a natural egress for add-on cabling. I agree that a tapered tube that one could wedge in there would easily support a platform for attachments. Fabrication of such a platform could be an entrepreurial opportunity just waiting for for the right person to implement! smile.gif
    edited 2009-11-30 02:57
    I love just such a challenge, Phil! Perhaps I will rise to the occasion and produce such a platform! Parallax has no plans? Seems like a small breadboard area on a post would plug in quite nicely with a ribbon connector to the hacker port...
    Speaking of which, do you have any idea what the hacker poer connection may be like? Scrib1's internal hacker port with itss 3 IO pin connections required the case to be opened (and warranty voided!), but I must assume Scrib2 will have an opening in the case with some multiconnector.
    edited 2009-11-30 06:44
    Pin allocation has been one of the most interesting challenges in the S2's design, and the hacker port is still a bit in flux. Physically, it will remain internal, however, so you will still have to open the case to get to it. I think the idea is to configure it as several 3-pin servo-style headers, each with Vss, +5V, and signal. 'Not sure yet how big "several" will be, but at least they'll be dedicated this time and not shared with any LEDs.
    edited 2009-11-30 15:50
    Yikes! Opening the case to access headers sounds like opening Pandora's box. Is Parallax encouraging that? Will it void the warranty? Adding an external port sounds better. The Prop has so much potential that NOT adding external circuitry would be a crime.
    I work in the toy biz with China manufacturers. It is easy, quick & cheap for any good vendor to modify the steel injection mold (namely, adding a shutoff) to create a hole (any shape opening) in the plastic part. And it is reversible, they can fill in the hole with another part if you ever decide to go back.
    But it does take some time. IMHO, I'd be willing to slip the delivery schedule a month to add an external port.
    edited 2009-11-30 17:59
    There's also power available on the DB9 for circuitry that can be interfaced via the serial port. And the DB9 has a snug enough fit to support a small board on its own.
    edited 2009-11-30 22:25
    Phil,
    Thanks for the encouragement! The DB9 is an option. The IPRE Fluke uses this method (as I am sure you know).
    erco,
    I've got some ideas if you want to talk.
    Whit+
  • BumpBump Posts: 592
    edited 2009-12-17 22:07
    Update, or rather an addition, to this post (or a Bump, har har); the Scribbler Family page:
    http://www.parallax.com/ProductInfo/Robotics/ScribblerFamily/tabid/825/Default.aspx
    When new information is made available publicly·it will also be posted on the associated pages.
    I think a word or two is missing from this sentence on the S2 page.
    "The Propeller has enabled us to provide a highly capable that brings forward so many new capabilities."
    Bean.
    1st rule of finance...Don't lose money.
    Never be ashamed of making an honest·profit.
    Live within your means...Make do, or do without.
