FSRW: She's So Unusual - Page 8 — Parallax Forums
1456810
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-11-25 06:43
    Thanks a lot, Cluso and Rokicki!
    But after my last post I had to go to bed. 5 hours sleep is minimum I need to make it through the week.
    Now I'm at work and can't provide a picture.
    Believe it or not, but I don't have a single tantalum capacitor left to try that. Hope to find one on a board in my trash-box that I can desolder.
    edited 2009-11-25 07:22
    I found some code for another micro to drive a SD card in SD-mode. Do you think it's worth a try to translate it to PASM or would the extra efford in reading 4 bits and putting them to the right place eat up the advantage of having 4 data lines?
  • dMajodMajo Posts: 862
    edited 2009-11-25 12:09
    MagIO2 would you pm me that code, pls?
    · Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
  • SapiehaSapieha Posts: 2,964
    edited 2009-11-25 14:18
    Hi MagIO2
    Can You post that code on Forum ?
    Regards
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    edited 2009-11-25 14:55
    http://www.mikrocontroller.net/topic/83407#new
    ZIP-file in the first post. Text says that this code is damn slow currently, but I think the important thing is to see how it works in 4-bit mode.
    edited 2009-11-25 22:13
    How funny! I found some old electronics boards with different capacitors. I tried several and I always got different return values for the boot-sector check. The closest I could get was $56, $AA .... ;o)
    So, tomorrow I'll put my SD card adapter on a prototype PCB with short wires and plug it directly into the breadboard besides the propeller. Hope that solves my problem.
  • whickerwhicker Posts: 749
    edited 2009-11-26 03:32
    not to beat a dead horse.
    but I was having major trouble with the SD card stuff when I had the prop-plug constantly plugged in on my protoboard.
    the process that solved it was:
    download new change to eeprom
    power off switch
    remove prop plug
    power switch back on
    plug prop-plug back in for serial comm stuff
    I was literally tearing my hair out.
    granted, it had something to do with the card communication being interrupted mid-stream by forced reset or power-off (my code couldn't always unmount, got stuck in a loop waiting on something else).
    But having that little bit of voltage there, just kept the card locked up.
  • rokickirokicki Posts: 1,000
    edited 2009-11-26 04:54
    I believe lonesock through heroic effort has solved that problem. I think he's found an
    initialization sequence that will get cards out of a "bad" state pretty reliably.
    If you still find it necessary to power cycle, let us know.
  • RaymanRayman Posts: 15,899
    edited 2009-12-01 17:42
    Can you guys say what kind of actual variation in read speeds you see with your new driver? Is it limited by the Prop, so that a faster card doesn't buy you anything?
    Just asking because I'm using the SD card as a video buffer. It's an old 256 MB card and I'm wondering if it's worth trying an "extreme" SD card...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    edited 2009-12-01 18:17
    For reading, it probably doesn't make much difference. For writing, it can definitely make a difference, especially with
    respect to "stuttering" (i.e., the overall bandwidth may be high, but some cards will pause on very big writes for quite some time).
    For reads, as long as you are doing big sequential reads, it probably doesn't make much difference. Indeed, it may be possible to get even
    faster for reads by arranging things so the PASM dumps the data where you want it rather than requiring a separate longmove() to move
    every chunk of data. Of course make sure you are using 32K sectors, and make sure your destination buffer is longword aligned.
    You should see about 1.6MB/sec; time it and if you're not seeing that, then we'll have to figure out why not.
    We had a table, but I notice the table is out of date, so I'll have to rerun the tests on my collection of cards.
    edited 2009-12-01 19:52
    So the read speed is limited by fsrw and not the card?· The wikipedia site seems to indicate that max read speed is higher in higher end cards:
    SanDisk classifies their cards as: [list][*]Ultra II — minimum read speed of 15 MByte/s (100x) [*]Extreme III — maximum speed of 30 MByte/s (200x) [*]Extreme IV — up to 45 MByte/s (300x) [/list]
    edited 2009-12-01 21:55
    Yep, pretty much limited by fsrw. We're using a one-pin SPI interface that tops out at, I think, 25MHz, and there's overhead to
    issue commands and the like. There may be a bit more headroom, but the one-pin/25MHz will limit us to just about 3MB/sec
    best case, and I think almost all cards can do that pretty easily.
    Note that at our current 1.6MB/sec we're doing single-instruction-per-bit collection, and then there's the loop overhead and
    the overhead to store to RAM. We might be able to improve things a bit more, but it's quickly getting into diminishing
    returns.
    But again, are you actually *seeing* 1.6MB/sec? If you're not, the first thing to figure out is, why not.
    edited 2009-12-01 22:22
    Well, I'd like to get an actual average read rate of ~500 kB/sec because 500 kHz is the lowest pixel rate that the video unit can run at...
    Right now, I use that rate but add in extra front porch to slow things down because my actual read rate is closer to ~200 kB/sec.
    I've already modified FSRW to write directly blocks to my HUB buffer, so I'm not sure what else I can do (easily)...
    edited 2009-12-01 22:30
    If you're only seeing 200kB/sec, something's very wrong. Most likely you're using the wrong version of fsrw, or you're using ppgetc() or something.
    Are you willing to put a zip file up here, or send it to me by private email?
    edited 2009-12-02 00:00
    Ok ·(You asked for it!).
    Here's the SPIN loop that fills the HUB RAM buffer on command from the ASM video driver:
      sd.popen(STRING("jeanluc.dat"),"r")
      i:=@buffer
      sd.pread6(i,buffersectors)    'modified FSRW to read fixed #sectors directly to HUB RAM buffer
      BufferFlag:=1
      lcd.start(@lcd_status)        'buffer is filled before starting video driver here
      'start buffer fill loop
      repeat
        repeat until bufferFlag==2     'video driver sets flag to 2 when starting new video frame
        repeat 16
          repeat until bufferFlag==0    'video driver sets flag to 0 sometime while reading buffer
          bufferFlag:=1
        'start over
        sd.seek(0)                      'reset everything
    And, here are the two constants in the video driver that I use to slow things down:
    PixelClock              long     500_000       '500_000+       read-only
    _hd                     long     1200'512'512       '1+             read-only
    edited 2009-12-02 00:05
    Just tried an newer, larger, empty card and was able to drop _hd to 1100... Not too much of an improvement...
  • lonesocklonesock Posts: 917
    edited 2009-12-02 00:10
    Just to be ultra clear, "buffer" is long aligned, right?
    Jonathan
    lonesock
    Piranha are people too.
    edited 2009-12-02 00:13
    yep, it's in the VAR section:
    long Buffer[noparse][[/noparse]bufferlongs]
    edited 2009-12-02 00:38
    It's likely that I'm doing something wrong...
    But, any chance the "GetNextCluster" routine takes a long time?
    Just in case we can't find the problem, can I just make a list of datablocks used by the file and then call
    sdspi.readblock(datablock, @buf)
    for each block?
    Post Edited (Rayman) : 12/2/2009 12:58:11 AM GMT
    edited 2009-12-02 00:44
    I would start by eliminating the buffer flag waiting and just do the I/O and see how fast that is.
    It looks like you are reading 15*512=7680 bytes for each image, and you are reading 17 images,
    so the total I/O is 130K. That should take a small fraction of a second.
    If the I/O is fast after removing the two "repeat untils" then the problem is somewhere in your
    code. If it's not, we'll continue digging in the SD stuff.
    I will mention here that you probably want to be double-buffering anyway, letting the SD fill
    one buffer while the LCD is rendering from the other, and then swap. If you have the memory.
    Is pread6() mainly there for speed? I'd also try using just pread() since with aligned buffers
    it should be pretty quick.
    edited 2009-12-02 00:46
    getnextcluster() should *not* take too long but there's always that possibility. The first way to
    try to "fix" that would be to just put the data on an empty card; that will make sure that it is
    contiguous.
    Are you sure this card is using 32K clusters?
    edited 2009-12-02 01:04
    It's funny... I removed the repeat..until and the image is almost stable on the screen.
    So, I'm pretty confident now that it's the SD card reading that is slow somehow...
    Maybe it's the seek(0)? But, I don't see why that should be slow either...
    I don't know for sure my clustersize... Do I have to format to know?
    edited 2009-12-02 01:09
    I've reformatted fat and 32k clusters, but same result...
    edited 2009-12-02 01:39
    Rayman: I find the file start location. I require the file to be contiguous. So from then on I use the fsrw low level to just read and write sectors directly. No file overhead. This may help you if you are not doing it that way now.
    The code is in the TriBlade thread (was the last page) version _rr130. FYI I also have to tristate the bus so there are a few extra calls to enable/disable the bus which you will not require and I disabled the read ahead (it's all commented).
    edited 2009-12-02 01:44
    Do you mean I find the value for the first "datablock" and then just do:
    sdspi.readblock(datablock++, @buf)
    edited 2009-12-02 02:28
  • AribaAriba Posts: 2,694
    edited 2009-12-02 03:33
    Rayman, here is a fsrw-methode to get the first sector of a file. Call it after open the file for read:
    pub GetStartSector
      return fclust<<clustershift + dataregion
    Andy
    edited 2009-12-02 03:39
    Ray,
    I simplified your code so I could run it without the LCD; the archive attached is what I ended up with.
    It talks to the serial port (and uses pin definitions as defined in sysdep.spin which you'll have to update for
    your system). I get a time of 6.24M clocks at 100MHz which is 62.4ms per loop. Each loop is reading
    131K so that works out to be 2.1MB/sec. Admittedly this is at 100MHz, but at 80MHz it shouldn't be
    slower than 0.8 times this or 1.7MB/sec.
    So it looks to be the waits, which implies it's the code updating the LCDs that is causing the slowdown.
    Run the attached code on your system (after updating sysdep.spin to adjust the clock frequency and
    the SD pins) and let me know what number you get on your serial port.
    -tom
    edited 2009-12-02 06:27
    Here is what I use to get the first sector of the file
    r := sd.popen(st,"r")································ 'Open file for read (blank image)
    CheckError(r)
    drive_base[noparse][[/noparse]n] := sd.getSDdatablock··················· 'get the sectorno of the file (returns the sector+1)
    I haven't checked the whole code, but I think the comment "sector+1" is wrong. I think its the first sector.
  • BaggersBaggers Posts: 3,019
    edited 2009-12-02 09:10
    Rayman are you also reading in multiples of 512byte sectors at a time?
    edit: ignore that, just looked at source, the thread opened at page 9, lol, I didn't see page 10 [noparse]:D[/noparse]
    Post Edited (Baggers) : 12/2/2009 9:17:19 AM GMT
