Important Prop II info
Just in case you missed it, check out this thread, especially response from Ken Gracey...
http://forums.parallax.com/showthread.php?p=857720
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
What we plan to do soon is fabricate a test chip so that we can prove all the subsystems that will go into the final chip. We are still a ways from being done with complete design.
Sorry to let you all down. I'm sure Ken didn't mean that the chip would be for sale in a couple of months when he mentioned a "shuttle run".
A shuttle run is where a foundry gathers designs from perhaps 40 different fabless chip companies and mixes them onto the same mask set, then fabricates perhaps 20 wafers. Afterwards, the various ICs are cut out of the wafers, packaged, and then sent back to the customers. This way, mask costs (about $180k) are shared among customers so that they can affordably try out their designs (well, at a cost of about $40k) and receive at least 20 chips.
We will do a shuttle run for the critical guts first, then another if we need to make changes to the guts, based on testing. After that, we will do a full-chip shuttle run, followed by perhaps another, until everything is perfect.
Chip Gracey
Kinda like PCBPool but for silicon. Cool idea [noparse]:)[/noparse]
If you always do what you always did, you always get what you always got.
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
On that "Shuttle run". I dont suppose you could sneek on a couple of P8X32Bs, PLEASE .
Style and grace : Nil point
It was a shameless plea, worth a shot. I remember seeing one micro that had a piggy back EPROM on its top. I suppose I could stick chips into a block of resin and hail the new contoller, with all the advantages.
You Said " I remember seeing one micro that had a piggy back EPROM on its top. "
I still have 2 that micros --- It was Z8 micros that in plastic comme with mask program and piggy was for development mask rom.
Regards
Christoffer J
It was nice news that some of my ideas comme with Propeller II.
Have some more that ideas BUT Chip not answer my PM's that give me no posiblity to give that ideas to Him.
And some of them I will never post on forum.
BUT still Propeller I have much to give ... All that people found Propeller can DO is not 50% what can be done with it.
Have good work with Propeller I'm to busy to post much on form ( Designing some PCB for PROPELLER I ) that is mostly done
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
