ICL7135 To a Prop Chip Software is being test and will in Completed Project Sh
·Would I need· any thing else to be able to read the ICL7135 with a Basic Stamp
··Data Sheet ...>>>··ICL7135
· Data Sheet ...>>>· HD-6402·......>>> I know that this chip is hard to get··· ·I do have a source to get this chip
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/24/2009 11:22:20 PM GMT
··Thanks for any·
Sam
You might be better off using a prop instead of the UART. Far more flexible and fewer additional parts are needed.
Post Edited (kwinn) : 11/19/2009 9:31:38 PM GMT
Will this Board work for this Project ^
With this board ^^^^if ·reworked for the ICL7135 Chip will this work
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 11/21/2009 1:37:44 AM GMT
Thank You
··Thanks for any·
Sam
If that is the case it certainly looks like it is doable. The only thing to watch for is that you do not use the pins for the meter board that are used by the Platform LCD UI Module. You will also need a + and -5V supply for the meter board. You can get the +5 V from the Propeller Platform Module but the –5V will either have to be generated on the board or provided by an external supply. If you decide to generate it on the board try to keep it as far from the ICL7135 analog circuitry as possible.
I will add· the - 5 volt power supply after I know that the main board is a good lay out
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 11/21/2009 4:16:26 PM GMT
I know that I do not have the rest yet I am doing one·piece at a time I am going to make this board a little longer to add the regulator for the ICL Chip
Please let me know what you think of this· board layout
I am not sure which type of display I am going to use so I Put all combination·so what pins I do not need those pins will not have resisters in them
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 11/22/2009 3:12:36 AM GMT
Please let know if you can see any thing wrong with this layout
I want to order some of these board soon
This is the first time making a board my self
so feed back is need and welcome
··Thanks for any·
Sam
Pin 1 should go to Vcc (V+) it now goes to P16
Pin 4 connects to digital Gnd, now goes to P19
Move pin 2 and 3 to P16/P17. No other connections are required to the prop so P18/P19 will not be used.
The transmit/receive from the max488 each requires 1 twisted pair of wires. Add a 4 pin header instead of the output connector. Pins 5-8 of the max488 should go to those header pins and stay in sequence (pin5 to header1, pin6 to header2, etc)
Please look at it· with a fine tooth comb·again and see if you find any more mistake very important that I have this right I only want to make boards that work right once
··Thanks for any·
Sam
1- V50 and GND are shorted on the bottom (green) layer of the PCB. Remove short and connect analog Gnd plane to GND connector at this point only
2- Vcc from the MAX488 should go to V50 on the top connector
3- V-, Vref, and both ends of the Vref adjustment pot are tied together. Connect as per the schematic.
4- V- from ICL7660 goes directly to V- on pin 1 of the ICL7135 only. If the V- is not required the ICL7660 can be left out and pin 3 and 5 jumpered to connect V- to ground.
Double check everything in the analog section very carefully. I may have missed something.
··Thanks for any·
Sam
at this REV7 Fix a few thing
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 11/29/2009 6:14:47 AM GMT
··Thanks for any·
Sam
I want to Thank You for writing the code for the ICL7135·Chip to Propeller Chip
Up-Date
I am working on the Pro-to Board ·right now and hope to have it done by Monday and once I have tested to see how it works we post the code for everyone
Here is the latest update Rev on the board
This is the pro-to board layout that kwinn use to test the code
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 12/24/2009 11:43:55 PM GMT
BOTH CODEs
Here is the code for the ICL7135 meter Chip
I Have not had time to test the new Meter board code yet but·I will try to do·it very soon
I had some time to test the code and it work GREAT
I test this code with·a meter board that I already had which the board has a clock Pulse already and the code is a little different
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/4/2010 12:05:50 AM GMT
