Multiple serial to ethernet access
Does anyone have any thoughts about how 2 or more computers could access the same ethernet virtual com port using a rs485 style communication where there is one master controlling the traffic? I just finished up setting up a lantronix vcp, and would find it nice if I could figure this out. Otherwise we will need to set up a separate digi xtend radio and ethernet setup for each computer that wishes to be on the monitoring network.
I have found very useful the products of Eltima (and use them always):
- Serial Splitter
- Serial to Ethernet Connector
- Serial Port Monitor
- VSP AX / VSPD XP
instead of accessing with 2 pcs on the remote ethernet2serial device you can use "serial splitter" to split the local virtual com on an phisical com and/or another virtual one using "serial to ethernet connector" and thus virtually daisy chaining the 2 pcs on the serial device server
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
Are you certain that tibbo allows multiple pc's to link to one serial setup? The only reason I used lantronix is that the digi ethernet radio uses the lantronix setup.
Is what you want? Any connected master (on the ethernet side) can transmit data to the serial port. And any data received by the serial port is transmitted to all connected hosts/masters.
That is correct, that is what I want.
BTW: I have downloaded one of the helps from the above post and find it unusable so this is the secon trial
PS Let me know if you can open them
Post Edited (dMajo) : 11/21/2009 6:57:36 PM GMT
