Simple Capacitive Touch Sensor — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2010-11-23 10:18 in Propeller 1
Hi All,
I am hoping to slowly ramp up the clocking freq until the input detects a high.
Then reduce the freq a little until the input becomes low again.
Then wait for any fingers to come close to increase the capacitance which will make the input detect high.
Can such a circuit work?
www.fd.com.my
www.mercedes.com.my
  • nohabnohab Posts: 96
    edited 2009-11-20 09:52
  • william chanwilliam chan Posts: 1,326
    edited 2009-11-20 13:51
    Thanks.
    I guess that was a simpler circuit.
    www.fd.com.my
    www.mercedes.com.my
    edited 2009-11-21 19:57
    william,
    Here is an interesting article that I have been holding on to, that covers a little bit of theory with capacitive sensors.
    Beau Schwabe
    IC Layout Engineer
  • bluesparqbluesparq Banned Posts: 2
    edited 2010-11-23 08:43
    Check out www.TouchSwitch.net
    They have a lot of capacitive touch offering.
  • BigFootBigFoot Posts: 259
    edited 2010-11-23 09:40
    STM has some interesting chips that would work with the Propeller to implement a touch based system.
    Hi All,
    www.fd.com.my
    www.mercedes.com.my
    Here is another way to do touch controls for a surface mounted switch. This one was used
    in a custom home shower to select your personal water temperature. We also used it to open a massive front door. It is completely water resistant.
    The propeller transmits a signal down the twisted pair which couples back into the input.
    When the disk is touched it shorts the weak coupled signal to ground, activating the
    switch. We used Cmos logic & 6800's back then but the Propeller input has a high enough
    input resistance.
    1608 x 840 - 65K
