repeat problem — Parallax Forums
repeat problem
pusinkpusink Posts: 68
edited 2009-11-18 21:30 in Propeller 1
i use window vista....i·write program like this....
Pub LedOn
dira[noparse][[/noparse]0] ~~
outa[noparse][[/noparse]0] := 1
waitcnt(clkfreq + cnt)········ '1s delay
outa[noparse][[/noparse]0] := 0
led on in 1s and off...i have no problem with that code...
the problem is....
Pub LedOn
repeat· '<
led not turn on when i put repeat.....
it is because propeller tool......?
Post Edited (KEELOQ) : 11/18/2009 2:09:41 PM GMT
  • ErNaErNa Posts: 1,862
    edited 2009-11-18 14:09
    use [noparse][[/noparse] code ] [noparse][[/noparse]/code ]
    Pub LedOn
    repeat  '<-------
      waitcnt(clkfreq + cnt)         '1s delay
    indentation may help
    cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
    Hello Rest Of The World
    Hello Debris
    edited 2009-11-18 17:29
    Indention is critical
    if you write
    repeat  '<-------
    where the commands below the repeat are NOT indented this means there is a empty repeat-loop
    if you write
    repeat  '<-------
    where the commands below the repeat ARE indented all the lines that are indented belong to the repeat
    repeat  '<-------
      outa[noparse][[/noparse]0] := 1                   'belongs to repeat
      waitcnt(clkfreq + cnt)         'belongs to repeat
    outa[noparse][[/noparse]0] := 0                   'belongs NOT to repeat
    waitcnt(clkfreq + cnt)         'belongs NOT to repeat
    best regards
    Stefan
  • pusinkpusink Posts: 68
    thank you very much......
