Powering up a Prop using an LDO with enable
DiverBob
I have a battery-powered Prop using 2 3.6 v lithium-ion cells. These feed a MicroChip 1802T 5V LDO with an enable input. What I want to do is use a Prop output to feed the LDO enable to keep the LDO on and therefore programatically shutdown the whole circuit by bringing the enable low.
The problem I have is that there are only 3 monentary SPST switches (piezo switches) available to supply the initial hi enable signal to start up the regulator. I have included a simplified dwg of the circuit as it stands now. I'm trying to figure out the best method of applying the +7.2V voltage from the battery to the regulator enable pin without burning out the Prop pins and using the existing switches. The enable voltage only has to be held long enough for the prop output to take over - its the first thing in the SPIN code.
Preferably I'd like 2 switches pressed at the same time to trigger the enable but at this point even a single switch press for enable would be OK.
I've been going slightly nuts trying to figure this out but hopefully someone has encountered something like this before. The reg is great for battery power, very little current draw when disabled.
When the switch is closed, the +7.2V pulls up the enable pin voltage through the diode and resistor to turn on the regulator. The resistor limits the current into the enable pin.
The Propeller normally has its I/O pin set to high-Z which should not affect the enable pin. When you set the Propeller I/O pin to output a low, the cathode of the diode is grounded and pulls down the enable pin turning off the regulator. When the regulator output drops below 2.7V, the Propeller will be forced into reset which will cause the I/O pin to become high-Z again. You probably will want a small capacitor (like 0.1uF ceramic) from the enable pin to ground to keep the enable pin high or low for a little while as everything shuts down or starts up.
The prop will have to be powered to power itself on. As there has been pointed out before there has to be a starting handle, this would only be able to power itself off. I am sure that a few months ago there were ccts to allow both ways, one was from parallax, if my feeble memory hasn't failed again.
Style and grace : Nil point
On Yours SCH You have 5V to Prop ... should it not be 3.3V
Regards
ChJ
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
I like the Chicken and Egg analogy - I hadn't thought of that one.....
I showed only a partial circuit diagram, the Prop is powered by 3.3v but the 5v reg supplies the 3.3 reg. I just decided to simplify the circuit to show the essentials.
