i need to knew how to program the PIC16F877A with the easy bluetooth module....
i want to do a testing about the bluetooth module, so i connect an up counter and a 7 segment decoder in one chip
and a PIC16F877A-I/P Microcontroller, 40 DIP, 20 MHz and i connect the the bluetooth module but before that i need to do a programing for the PIC and burn it using a PIC burner..
i am not good in coding things
so can i found any ready program for the EASY BLUETOOTH MODULE can be burn for the PIC at least when i want to connect them using the hyperlink terminal when ever i press a number can be seen?????
i tried other company module with there own programing for the PIC using a C language....i got the segment with the number i press so i tried to test PARALLAX bluetooth on the same thing but cant work means that i need to burn its own programing..........................any person can help me to find the program for the PIC to use it in send and recive the signal of the bluetooth??????
thanx for your help
thanx for your help
Mike2545
This message sent to you on 100% recycled electrons.
