i need to knew how to program the PIC16F877A with the easy bluetooth module.... — Parallax Forums
wavestorm1986wavestorm1986 Posts: 12
edited 2009-11-16 18:11 in BASIC Stamp
i want to do a testing about the bluetooth module, so i connect an up counter and a 7 segment decoder in one chip
and a PIC16F877A-I/P Microcontroller, 40 DIP, 20 MHz and i connect the the bluetooth module but before that i need to do a programing for the PIC and burn it using a PIC burner..
i am not good in coding things shakehead.gif so can i found any ready program for the EASY BLUETOOTH MODULE can be burn for the PIC at least when i want to connect them using the hyperlink terminal when ever i press a number can be seen?????
i tried other company module with there own programing for the PIC using a C language....i got the segment with the number i press so i tried to test PARALLAX bluetooth on the same thing but cant work means that i need to burn its own programing..........................any person can help me to find the program for the PIC to use it in send and recive the signal of the bluetooth??????
  • Mike2545Mike2545 Posts: 433
    edited 2009-11-16 12:02
    Wavestorm, this is a forum for Parallax and the Basic Stamp, for PIC programming questions you should check out the Microchip user forums at : www.microchip.com/forums/
    Mike2545
    This message sent to you on 100% recycled electrons.
    edited 2009-11-16 17:53
    do you have a parallax basic program that works with this module on a basic stamp?
    Almost all Parallax products have links on their webstore page to documentation and to sample programs. Look at the webstore page for the Easy Bluetooth Module for these.
