5MHz quartz with small housing required
ErNa
Hi,
I wonder where to find a small 5MHz quartz, for the standard HC-form turns out to be the biggest part on the board. And, on the other hand, wouldn't it be nice to have a higher frequency, for example 10MHz, for the prop II as a standard? This will solve that problem.
Any advice on the forum?
ErNa
cmapspublic3.ihmc.us:80/servlet/SBReadResourceServlet?rid=1181572927203_421963583_5511&partName=htmltext
Hello Rest Of The World
Hello Debris
Install a propeller and blow them away
ErNa
Hello Debris
*Peter*
Reichelt has in 5x7x1.2 mm (smd) 10 & 6 MHz oscillators, there is a smaller form factor but they do not seem to have many of those. And in HC-49 there are two besides the normal 13 mm high one, the smd version and the low-profile for through hole. The low profiles work great with the prop and are reasonably small.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Nothing stopping you using a 10Mhz with the prop now...
If you always do what you always did, you always get what you always got.
Tracy Allen
www.emesystems.com
I have use the really small and flat rectangular crystals but they are expensive and unless I am really concerned about size or stability then there is no need to use them. The ones I used where 10MHz as 5 was not available and there is no problem with 10 vs 5 I guess, just standardization.
*Peter*
ErNa
Hello Debris
····http://forums.parallax.com/showthread.php?p=809968
A program that uses clkset.spin will run with 5MHz or 10MHz crystals without changing any code or constants.
Found it at Mouser using the P/N provided above by another poster.· Have it on order.
Post Edited (Eagleman) : 12/17/2009 3:55:18 AM GMT
