CNC SMT Pick and Place Video Update — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2009-11-12 14:30 in General Discussion
I finally got some time to edit some video I shot of the machine placing parts. It really needs 4 camera angles, and there was no way to do it on a tripod with one cam, so I apologize for the shaking. The project is a GUI that sends strings to a Propeller which drives 3 steppers and a vacuum on a small benchtop CNC machine mod'ed with a servo and syringe for picking up parts. The image is the GUI I created that imports a text file that is outputted from Eagle with X and Y for all the parts. Just a few tweaks to program in the packages for the parts plus any orientation changes, and it is smooth sailing after that. There is no auto feeder yet, I have some ideas but realistically it goes very quickly by hand with very little error. Compared to the old school method of tweezers and a hand rest, there is no comparison to how much easier it is, there is very little thought process, the app calls up the parts as you go, as one part is running just be getting the next part ready. For mutiple parts of the same value, there is a one click Run ALL value, just feed the tape and watch. This was a LOT of fun to build and is extremely helpful building my product PCBs.
Anyways, I uploaded a Hi res video, looks better in HQ.
www.youtube.com/watch?v=jW0z5Hct3xU
Here is the app screen shot:
Post Edited (Todd Chapman) : 11/9/2009 5:00:21 AM GMT
  • metron9metron9 Posts: 1,100
    edited 2009-11-09 04:11
    Awsome, nice work.
    Have you thought about using a vacuum tank and selonoid valve to turn on and off the vacuum and putting that awful sounding vacuum motor way way far away so I can hear the stepper motors and servos go swish zzzz click. For something with such nice precision it should sound like a nice sports car.
    What brand is the small benchtop CNC machine or is it a home brew as well?
    Think Inside the box first and if that doesn't work..
    Re-arrange what's inside the box then...
    Think outside the BOX!
  • T ChapT Chap Posts: 4,260
    edited 2009-11-09 04:15
    Well, I just used the quickest fastest thing I could think of for vacuum, it sounds much worse in the video. I put in in a box now with some insulation. Maybe one day will try another method. It already has a solenoid on it that open up the lines when the part is placed, closes the lines when the vacuum is on, so a vacuum tank would plug right in. I wouldn't want to give the CNC company any advertisement!
  • James LongJames Long Posts: 1,181
    edited 2009-11-11 05:42
    Todd,
    I'm very impressed with your work so far.
    I have a few questions........
    Have you considered future operations, and how you will accomplish those?
    I was specifically wondering about rotation of a part, and squaring of the part to the placement.
    I like your approach so far. I also recognize the machine. I wouldn't talk about it either. A partner and I started a CNC business with one of those......and bought a different machine right away. It was good for rough medium fast prototypes, but not much else.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
    edited 2009-11-11 06:13
    I am not sure what you mean by future operations, maybe explain that a little simpler for the dense minded. If you mean auto feeder, I am thinking about a servo pushing a pin that pushes the tape in fixed increments, or maybe a manual semi precision feeder. Manual with eye balling it is very easy though so I don't really mind it.
    As far as rotation, on a chip like a QFN I do a little micro rotation, I just drop those to about 90% of the move to the PCB, tweak it left or right by small amount of degrees and place it. It takes maybe 15 seconds to tweak in a fine pitch part. Larger chips place just fine. I don't square any passives, maybe just a slight amount here and there on IC's. I set up a micro rotation feature to move left or right just a tad or as you set it to move. Out of a few thousand parts now I don't have any issues yet. It gets pretty easy after a few boards. In a month or so I will have someone doing it for me in house along with milling other parts.
    This machine works great after you rebuild it from scratch, I have new motors, nuts, screws, controller and Geckos. It comes with a solid Taig spindle already so that is a plus.
    Post Edited (Todd Chapman) : 11/11/2009 6:25:08 AM GMT
    edited 2009-11-11 06:30
    Todd Chapman said...
    I was just wondering how far you were going to take the machine operation. It is pretty neat for a home built solution.
    James L
    James L
    Partner/Designer
    edited 2009-11-11 06:37
    Oh, my plan is to build a machine from scratch for assembly in the next few months.
    edited 2009-11-11 06:40
    Cool, keep us updated. Sounds like a neat project. I wanted to build a machine from scratch, but found a series of obstacles I didn't want to over come.
    James L
    James L
    Partner/Designer
    You may want to look at ebay and search Mikroprecision, the bridgeport I just bought came from the previous owner of that company. They built xyz tables for hard drive mfgs.
    This item http://cgi.ebay.com/MikroPrecision-inferometer-platform-PZ-06-SC-SF_W0QQitemZ370232748658QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5633976a72
    Sold for $18,000.00 the Z access is machined from a full block of aluminum, the XY table is something like .00001 tol ball screws and ball bearing slides.
    He said one table listed for $1000 right now was a $30,000.00 table basically used for inspection with microscopes. I think the table has linear slides super fast movement.
