Parallax USB2SER Development Tool project help
Hi,
i am interested in using the usb dev tool for two different projects and i was looking for some help
here is what i would like to do:
1) i want to make a usb game controller that can interface with any or most games that a standard off the shelf device would,·for instance·a joystick or steering wheel and pedals
2) make a usb interface device that could be controlled
····· for example a remote controlled car with gps and temp sensor on it
·············· i realize that if i wanted to present data like temp and gps that i would need some sort of interface software on the pc, but the simplest version would be a car that i could control with an existing steering wheel and pedals from logitech for example or the one i made in section 1)
i was just looking for some starter points or ideas or anything that could help
thanks
cab
thanks
cab
It's a USB client or slave and can only be attached to a USB host like a PC. It can't control any other USB devices, so #1 is impossible without the PC doing pretty much all the work.
As a USB client, it can only send and receive serial info from a PC, so you'd have to have interface software on the PC where other devices might be plugged in (like a steering wheel and pedals) and the interface software would send info from the "other devices" to the USB2SER where it could be acted upon.
One exception might be to have a Vinculum chip based USB host like the Parallax Memorystick Datalogger. You can use one of these as a USB host and can plug in some USB devices instead of a memory stick, like joysticks and keyboards. You might be able to get the Logitech devices to work with it, but that wouldn't use the USB2SER adapter.
thanks for the quick response as usual
i am interested in interfacing with a pc and i dont mind if it does all the work
for· 1) i want to plug it into my pc and use the device as a joystck for my game
and for 2) i want to plug the cotrolled device into my pc and control it with either a sw program that will have gui or with an existing usb device
does this help?
if i cant do this with this product what can i use to build a standard usb human interface device
thanks again
cab
