Parallax USB2SER Development Tool project help — Parallax Forums
cabracercabracer Posts: 11
edited 2009-11-07 05:55 in General Discussion
i am interested in using the usb dev tool for two different projects and i was looking for some help
here is what i would like to do:
1) i want to make a usb game controller that can interface with any or most games that a standard off the shelf device would,·for instance·a joystick or steering wheel and pedals
2) make a usb interface device that could be controlled
····· for example a remote controlled car with gps and temp sensor on it
·············· i realize that if i wanted to present data like temp and gps that i would need some sort of interface software on the pc, but the simplest version would be a car that i could control with an existing steering wheel and pedals from logitech for example or the one i made in section 1)
i was just looking for some starter points or ideas or anything that could help
thanks
cab
    edited 2009-11-07 01:31
    Keep in mind that the USB2SER only does one thing ... it acts as a USB serial port and provides serial data out the transmit pin and accepts serial data on the receive pin. It also provides a "reset" signal triggered by a change in the DTR control line. That's it.
    It's a USB client or slave and can only be attached to a USB host like a PC. It can't control any other USB devices, so #1 is impossible without the PC doing pretty much all the work.
    As a USB client, it can only send and receive serial info from a PC, so you'd have to have interface software on the PC where other devices might be plugged in (like a steering wheel and pedals) and the interface software would send info from the "other devices" to the USB2SER where it could be acted upon.
    One exception might be to have a Vinculum chip based USB host like the Parallax Memorystick Datalogger. You can use one of these as a USB host and can plug in some USB devices instead of a memory stick, like joysticks and keyboards. You might be able to get the Logitech devices to work with it, but that wouldn't use the USB2SER adapter.
  • cabracercabracer Posts: 11
    edited 2009-11-07 05:39
    mike,
    thanks for the quick response as usual
    i am interested in interfacing with a pc and i dont mind if it does all the work
    for· 1) i want to plug it into my pc and use the device as a joystck for my game
    and for 2) i want to plug the cotrolled device into my pc and control it with either a sw program that will have gui or with an existing usb device
    does this help?
    if i cant do this with this product what can i use to build a standard usb human interface device
    thanks again
    cab
    Both the Propeller and several different PICs have the ability to behave like a USB HID. The problem is that they all cheat and don't really behave like a real HID according to the USB standards. For most PCs, that's good enough, but don't be surprised if they sometimes don't work. Again, you can't do #1 with any of the USB devices that Parallax sells. Like I said, you might be able to get a Propeller to fake a USB joystick, but it might be easier to buy a cheap USB joystick and hack it to do what you want. You can do #2, but not the way you want. Your "controlled device" can communicate with a program on the PC using serial data (via the USB2SER). One example of this is StampPlot Pro which has a GUI (here: www.parallax.com/tabid/441/Default.aspx).
