Tentative dates for UPEW/UPENE 2010
Oldbitcollector (Jeff)
Hey Gang grab your calendars..
Here are the "tentative" dates for UPEW/UPENE 2010
I'll confirm these as we get both locations locked down.
UPEW: Rockln, CA @ Parallax June 27, 2010
UPENE: August 28, 2010
OBC
New to the Propeller?
OBC
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
OBC
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
No.. That's why the location wasn't indicated.. yet.. We might even move UPENE around a little. [noparse]:)[/noparse]
OBC
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
I'll try to be there!
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Want cheap wholesale electronic parts?
Transistor parts wholesale
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
oh no! I promised my daughter we'd go to Cedar point next year!
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Jim Fouch
FOUCH SOFTWARE
Would the format be the same for UPEW? I loved how it was this year. Of course, Chip was looking a bit worn out by 3am Sunday morning.... lol Most of my vendors kick me out way before then.
Jim Fouch
FOUCH SOFTWARE
keep the doors open late, say 11:00pm or so. We had good things going on all the way to 1:00am last year.
The brave few who tried to run a full 24 hours were found in interesting sleeping positions around 5am. [noparse]:)[/noparse]
(Yes, we have pics!)
OBC
Personally, as a broke college kid I like the open 24 hours option. It saves on a hotel room for a night, and the transportation required to get there and back.
Is it as hot at end of May as end of June?
No car. I took the train last time, spent the night enjoying downtown Sacramento... (of course, it was a couple days before since I had to plan a day to get from Sac to Rocklin, but you get my point).
http://forums.parallax.com/attachment.php?attachmentid=61868
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Parallax Inc.
And I may have a few other interesting products by then too [noparse]:)[/noparse]
I've only been there once, and it is like a second mecca only to Parallax.
I wish I hadn't been so "under the weather" last year.·Next year I will definately try for the all-nighter.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
When I used to consult a lot in California I went to Fry's many times...
Hmm...a pilgrimage to Rocklin: can the local lodging industry handle it? Hmm...maybe if PhiPi fixes the A/C, he will make a "philpilgrimage." Gee...I need some sleep!
Interesting non subtle hint about PropII... I like this idea.. [noparse]:)[/noparse]
OBC
It would be, but I'm skeptical on the timing. You (rather, somebody at Parallax) realized there was a shortage of Propeller chips sometime early this year, say in May. The chips are scheduled to arrive in December, so that is 8 months from need to arrival. For the Prop II, I'm sure that you'll want to do extensive testing to make sure that everything is good as expected. Maybe a month for the tests. So, if it takes nine months from ordering to shipping then the Prop II design would have had to be completed sometime in September. Can Parallax keep a secret like that? I don't know, I wasn't around for the Prop I development.
On a slightly less gloomy side, UPEW (or UPENE) would be a great place to release initial documentation.
