About Propeller Proto Board
Hi:
The Propeller Proto Board (32212) needs the Prop Plug or the
USB2SER Development Tool.
Both are need to connect to the PC. Which is better, the
Prop Plug (32201) or the USB2SER Development Tool(28024).
Thanks Joe
Thanks Joe
Then, differences between those
products are about physical connectors only ?
( No electronics differences) :
Parallax USB2SER Development Tool -- 28024
Prop Plug -- 32201
Parallax USB to Serial (RS-232) Adapter -- 28030
Thanks Joe
PS: I added Parallax USB to Serial (RS-232) Adapter -- 28030
because it seems all are the same thing.
as the "datasheet" of the USB2SER (#28024) it is a 5V-device
the prop-plug is compatible with 3.3V and 5V-devices
the Parallax USB to Serial (RS-232) Adapter 28030 the soresite does not provide any information about electrical specs
of the 232-side.
As it is a called "Parallax USB to Serial (RS-232) Adapter" it MIGHT be that on the 232-side it has standard-RS232-PC-voltage-levels which means +-12V
So for this case you would have to add a voltage-levelshifter like the MAX2323 to shift voltage-levels from -12V/+12V to 0/3.3V
best regards
Stefan
