Cheap propeller programmer...
Howdy...
This is cheap Propeller programmer that came out of the discussion in the Propeller Forum...
http://forums.parallax.com/showthread.php?p=845658
I used the Nokia cable from the thread, you can find the link right here,
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370185543289
This is a Data Cable for Nokia 6101 6102 6102i 6103(CA--42).
Take it apart and add a 2N2222 or similar NPN Transistor, 2x10K (Brown Black Orange) resistors and a 10nF (103) cap.
The case comes apart pretty easy, cut the cable on the inside and pull out the cable to get the blue "cap".
Put a header on the ribbon cable and mark the "up" side.
On the programming header, the top one is the Ground, followed by Reset, Tx and Rx.
Note that I marked the ground wire with a black marker.
Flat side up, solder the two resistor to the Base and Emitter on your transistor.
Try to use as short leads as possible if you want the whole thing to fit in the case.
Hook up the ribbon cable. The bottom connection is the ground, unfortunately you cannot see the black marking I did on the cable.
The rest goes as in the picture, use the reference above to hook up the ribbon cable.
Collector goes to Reset on ribbon cable and add a ground wire to Emitter. The ground wire is kind of hard to see but it is the small blue wire in the picture.
Add cap to the resistors and the DTR on the plug. Notice that I lay the Transistor on the side and bent it a bit, I had to do that to make it fit in the case. Be careful not to disconnect the little red wire from DTR, I don't know if it works without it, but better safe than sorry.
Make it fit in the case, it can be a bit tricky but keep in mind that the transistor is laying on it's side.
Don't squeeze the lid on, it should snap on without a problem.
Hook up to Propeller.
Test it. I put some electrical tape around the plug to hold it together...
Have fun a and keep in mind that these are so cheap that you can make a few and give to your friends so they can get started with the Propeller...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Experience level:
/Bamse
Robert
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Why do we need a Nokia cable?· Why can't it just be built from scratch?
It is a great idea but $6 for shipping·plus a·cable and another $6 shipping or so for a transistor and resistors adds up.
Why not just either make it in a batch or buy a programmer for the prop?
@Chuckz,
The cable was $3.39 including shipping last time I checked the link, hard to beat.
I understand that if you don't have the components, it might not be such a great deal.
Personally I'm not interesting in putting together a kit or making a batch, but if anyone else is, please do...
Could this be something for Gadet Gangster to pick up ?
Experience level:
/Bamse
Because this is probably one of the cheapest ways to get a USB to Serial conversion cable. It is much more than a USB connector, housing, a couple resistors, and transistor. There is also a chip onboard that is handling the USB to Serial conversion. To do something similar you would have to at least get one of the FTDI chips which costs more than this whole cable. From the looks of it you could easily just ignore the DTR portion and just wire the GND, RX, and TX to any Propeller pin (or BASIC STAMP pin) and use this as a way to use any microcontroller to talk to a PC (or MAC) using a USB port for data logging, etc. This is a very good find.
I found a new one on Amazon for less than $3.00 and they also have a used one.· Shipping was about $3.00.· I don't know if I could do better than that but I'm not dissatisfied with this price when it comes to experimenting.
I'm running Ubuntu and Brads Spin Tool...
Experience level:
/Bamse
Thanks for the reply.
Hope that helps...
Experience level:
/Bamse
There was no shipping charges for the ones I got and they arrived pretty quick. Once this windoze thing is resolved these will be nice usb interfaces.
Again thnx.
Fixed the DSR typo.
Post Edited (Propability) : 11/3/2009 5:22:09 PM GMT
and thanks Bam for all the time you spent helping me, I think in the end I was having a problem with the circuit acting weird with stray capacitance, I edited my post but like I said my cables only worked if I had my scope probe attached so it had to be in the capacitance,
but with Propability way I just used the one capacitor I have 6 cables working fine thanks guys I am going to build one for every prop board I have
Oh if anyone wants a copy of the driver sI am using just ask.
Post Edited (mikediv) : 10/28/2009 9:04:24 PM GMT
To be on the safe side, I put a .1 cap between Gnd and Rx as mike suggested...
Experience level:
/Bamse
the 2 I have built using your circuit with the reset are permanently soldered to a project for controlling a ditch digger , they have a desktop system that services all there equipment mostly Can and I needed a reliable way to access the prop portion of the digger I hard wired the cable becuase they would loose it in a day plus you would not believe all the different cables they already have this way it stays with the machine , Bamse the reset is very nice I could never imagine how handy it would be until I needed it.
Thanks again guys I now have 12 cables built and working , which ever way you build one this can not be beat . The company does not charge for shipping so for 3 bucks you get a prop programmer not to many deals in life this is one.
Bamse just a thought have you ever thought about sending this to gadget gangster ?????? or selling them yourself just imagine a USB prop programmer for $8.00 dollars and you would still make a buck LOL
Thanks Guys
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
If you figure it out - let me know. Would love to use these silly cables if possible. It was cheap enough for me to order another three from the supplier that was listed above in the original post. So either I will have 6 cables for 3$ish or 3 cables for 6$
Daniel
then I did the 1 cap mod the only problem I ran into is like Bam said I had to add a cap to Gnd and RX I had to do this for all my cables to work right
Robert
Not quite - these ones are slightly different - they have 6 pinouts on each side and have no markings for RX, TX, but rather 1 through 12.
I can tone-out what the 3 soldered connections are, but where that darn DTR pin is, I might be at a loss.
Post Edited (OakGraphics) : 11/5/2009 12:52:36 AM GMT
How to find DTR? Well first of all the device should be recognized by your system so the drivers need to be installed and the device recognized with no errors.
For windows I use Brays terminal which allows me to toggle the DTR line. Of course you must have the correct comm port selected (device manager knowledge very helpful).
So plug in the adapter ( I used a USB extender for easier access to the pads) and then I would toggle the DTR button in Brays and look for the change of state with the voltage setting on my ohmeter.
When I did mine I noticed DTR was sitting at about 3.3V when first plugged in so I knew that the cap only would work since the pupose of the transistor in the prop plug was as a signal inverter.
A high to low tranistion on the cap is what causes the reset to happen for simplicity sake.
Hope this helps.
Duck
With the PCB tabs labeled as Pin 1-6, 7-12 on other side.
I can strip one all the way down if you think that will help you out let me know maybe the other side is of this is closer the what you need?
An earlier post asked if I was interested to put this programmer together for Gadget Gangster and the short answer is no...
However if anyone is interested in doing that, please go ahead, it would be a nice addition to Gadget gangster...
Just one disclaimer, I didn't design the reset circuitry, I found it in an earlier post in the original thread...
Experience level:
/Bamse
I wouldent worry about it. Because the driver came on a mini-cd, I can't install the driver till I transfer it to a flash drive. (I have a slot loading laptop)
Once I put the driver over, I will be able to try some more testing to find out where the DTR pin is.
PIN-OUT of the "12 PIN" type:
I noticed that DTR and RTS are about 3.3v when not active, and go to 0V when I toggled them on.
I guess this version only needs the two caps.
I'm still wondering why the need for the cap on the data (RX) line. Mine work fine without. If something is buggy and probing it with a scope makes it work then there is something else wrong. Just try it first without the cap on the data line.
I've also got one that I put a 1K resistor in series with the data(RX) line and used it to communicate with a 5volt device (mega168) and was able to do a reset of it ( a la arduino) with the reset line . Don't know if the chips used are 5volt tolerant so I didn't want to risk it. This also allowed me to use it for comm's with my SX's. Just marked it with a big "5" so I knew which one to use.
