RAM RAM RAM how much do you need?
Well there are lots of people making RAM modules in different ways. I still have designs for a bigger RAM module with built in HDMI output but I wanted something simpler and cheaper to offer in the mean time.
Ale gave me a great idea PSRAM. Cheaper then SRAM but as convenient to use other then the form factor.
I have designed a stackable 8M Word RAM module. These modules can be stacked up 8 high and act as a single 128M Word RAM Module. The tallest header I have found though is 95066-230HLF which would only allow for stacking 4 high so 2 stacks would be needed for full RAM area if you need that much RAM.
Random Access Time is 70ns however the modules support a 133MHz burst mode for sequential read/writes.
This is not a direct replacement of MITs 16MB RAM Module for $900 but each module does hold the same amount of RAM you just need to provide your own glue logic which is not expensive.
Each RAM Module would cost $39.99. I need to sell at least 25 and was wondering if there is enough interest.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
It needs a bit of glue logic. I'm working on a FPGA-geladen board that will support this module too. If there is interest, mctrivia could provide boards for that.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
It seems that the actual RAM size is significantly increasing the price.
We're all used to dealing with 32K limitation. Any xMB increase would be a huge upgrade,
but honestly I'd be happy with an additional 32K-256K solution, adapted as "standard"
Is this even possible? It seems that if it were the price would be considerably more in line
with what hobbyist budgets (and their spouses) would more easily allow. [noparse]:)[/noparse]
A smaller $10-$19 solution would be reachable by even our youngest members.
The beauty of the SD solution is that it is high storage at little cost. Can our memory solution match it?
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 11/3/2009 6:08:23 PM GMT
If you only need 256k don't use all the io lines. I could not economically make a board much cheaper even if I cut the size down a lot.
32K is easy and cheap - just get a Microchip 23K256 SPI SRAM chip [noparse]:)[/noparse] It's a nice easy 8 pin dip, and with a modified version of Kurenko's counter based SD card code should be able to do reads/writes at 20Mbps.
The problem with any memory add-on (or any board as a matter of fact, especially if designed to sell for even a minimal profit) is the overhead costs.
Rough example:
ExpressPCB = $55 or so for 3 boards, making it $18.33 per board. To get cheaper boards, you have to make a lot more of them, but if you know where to go, you can get small boards, qty 100 or so, for $3-$5 each. Less in larger quantities.
Assume you have to do at leat one prototype run. Can't use ExpressPCB - they don't take gerbers. Assume $80-$100 for the initial prototype run.
To get the memory chips at a decent price, you have to buy them in quantity. let's say you buy 100x 512kx8 chips, for just over $3 each.
Now you need at the very least a decoupling capacitor, and some pins... plus some latches if you don't want to use all the prop pins. But let's use the prop pins. say $1 in qty 100 for the caps and the pins/headers.
What do we have so far?
$100 (proto PCB)
$300-$500 (production PCB's)
$350 (100 memory chips)
$100 (cap and pins)
$150 (approx minimum shipping for above)
$1000-$1200 for 100 saleable boards.
Now let's not forget about all the time spent laying out the board, testing it, chasing down best prices, ordering parts. Or taxes, duties, etc.
Let's not forget having to fork out $1000-$1200 up front before selling a single board.
But for this simple calculation, let's forget labor costs.
Now if you want to sell to distribution, they want 40%-50% off MSRP, so you have to double the sale price just to break even.
So without labor costs counted, and with no profit, you are looking at a for sale price of $20-$24 per board, assuming you sell all boards.
Now if you actually want to be paid even minimally for your time, and want to make even a little profit, you have to double that again.
Now we are at about $40 - $56 for an extremely dumb, simple, 512KB board as a kit, without even a socket for the memory chip, that uses almost all of a propeller's pins (or at least half that if sold directly... but then we have PayPal fees)
And you have zero certainty of selling all the boards.
Using a smaller memory chip, say a 128Kx8, would save you about $1-$2 on parts costs, say $4-$8 on kit price.
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Post Edited (Bill Henning) : 11/3/2009 7:04:14 PM GMT
I'd want to see details on how to operate it - address initialization, control pins needed, the time requirements of the various states, and if there are any limitations, such as if the RAM refreshes itself, do you have to halt updates periodically to allow the internal refreshing to take place, and how often and for how long, that sort of thing.
For my current project, I'd want at least a meg, but wouldn't need any more than a few megs, so I wouldn't care about stacking.
I've already used a 512K static RAM chip with hand-wired counters to auto-increment the address for a similar project, and that chip cost something like $17 a few years ago. So I could see paying that price for your board if it would work in my project.
I will upload the chips data sheet when I get home in a few hours.
133mhz is fastest transfer rate so 5mhz should not be a problem.
Some notes:
*CS is reversed in the module so it is active high instead of active low.
*Address lines 23-25 can be used in place of CS if you need to save pins.
I was wondering if your board could have 2 mm connectors instead of 2.54 mm
I would prefer to use 2mm because of lower profile slightly cheaper headers available and making my board 8mm shorter but the lack of easily usable male headers is a problem.
Post Edited (mctrivia) : 11/4/2009 4:27:53 PM GMT
Because there is no clock pin available on header burst mode can not be utilized.
The read/write time is 70ns for true random which is slightly slower then the bus can handle but if you only change addresses A0-A3 the read/write time is only 20ns so with optimization in code it can run almost full speed.
I mention it because I am trying to see if there is enough interest to sell at least 25 modules before I invest the $1000 into a product run.
1 - The correct spelling seems to be "kuroneko"
2 - kuroneko didn't do the code in FSRW
3 - kuroneko did something earlier and similar (not targeting SPI, though) here: http://forums.parallax.com/showthread.php?p=784536
[noparse][[/noparse]8^)
Jonathan
lonesock
Piranha are people too.
I appreciate this, and hope I didn't come off as presenting mctrivia as ripping folks off.. (not my intent!!)
I just wish we had a solution as elegant and cheap as the SD storage solution. Almost anyone can
assemble an SD interface under $5.00, and a "commercial" product can be purchased around $20.00.
It might make an interesting poll to see what the typical hobbyist budget is for regular purchases.
(For me, I can spend $20-$30 here or there without spousal discussion. [noparse]:)[/noparse] There's no chance
of my purchasing one of those $4,000 gas powered Parallax bots any time soon. [noparse]:)[/noparse]
OBC
I am currently $200 short of breaking even for my breakout board for Raymans LCD
My propmodules I am several hundread short of breaking even.
As for your question I get $125/month allowance. Everything else needs to be talked about and agreed on.
but Oldbit is spot on about the hobby thing it would be awesome if I could (and have tried) to just wire up 256K or even a 1M I bought a few SPI flash rams from sparkfun actually one is a,, AT45DB161D,,16Meg with a carrier board for 6 dollars but I do not posses the software skills to get it to work. I fully understand MC the need to be able to make money and I mean no insult but a even a $20 dollar ram kit with software would be such a great upgrade especially for us neewbies my coding skill are so lacking that my code is huge and I always run out of ram
mctrivia is there anyway a a quantity purchase from you would make it economically visible for you to build say an"AT45DB161D" kit that would work with the prop chips????? Please understand I claim no special knowledge of how to do this
just asking out loud.
You have mail with dimensions [noparse]:)[/noparse]
If you map it as 4MB, I can generate a clock on A0, but you will have to "shift right" the address bits by one... ie:
A23=1 is your chipselect
A22 is your A21
A21 is your A20
A1 is your A0
A0 is your clock for burst mode
I know, it will use 8MB of address space for 4MB of mapped memory, but we can have 32 4MB pages with burst mode...
Best,
Bill
thanks for the correction!
OBC:
you are welcome - I figured lots of people did not know what was involved in bringing even a cheap PCB to market, so I thought it would help if I showed the process.
mikediv:
a $20 ram kit is not workable. See my response to OBC earlier in the thread.
A bare board without parts is possible, but then you will have to run around sourcing parts, and paying shipping to multiple vendors, paying a lot more overall.
Can start burst by writing a 1 to bit 4 of io port. Then set start address and then start clocking. After 3 clocks start streaming data.
so the I/O port could be:
BXXXXPPP
where
X=don't care at this time
B=Burst mode
PPP=page address
This would allow for up to 128 pages later - in case there are bigger modules in the future.
How about using A0-A2 for adv/clk/cre during burst mode? ie
A0 = clk
A1 = adv
A2 = cre
yes that should work.
I want to keep to 8MB block because it would let me use the same PCB for both a full blown multipage version and a cheaper single page version.
The single page version would not support burst mode though and have the module directly soldered on.
it can't really be 16M can it? Does the fact the Prop is 32 bit not significantly lower the actual ram available? I am very un-clear on how this works I have a basic understanding of 8 bit 16 bit 32 bit and so on but how would that relate to a serial ram device?
Thanks guys I just do not understand why it wouldn't be an easy task to interface a chip like this???
The atmega chips are a fallback for me but I very much want to conquer the SD card code as it opens up so many possibilities.
With respect to how much ram, it depends what you do with it. Working code that is being used as part of a program logically would be SRAM. For me, 512k is perfect. But 32k is not nearly enough. But for storage, SD would be the best. An operating system like CP/M (or PropDOS) logically seperates the two tasks - you have programs that you store somewhere, that are written occasionally and read somewhat often, and for that function an SD card is perfect. The speed is not so important when 'loading' a program. But for working memory where you want speed and random access, SRAM is the best. The atmega chips possibly fill a niche somewhere inbetween.
As an aside, I've got all these old PCs lying around from 10 years ago that have 32megabyte and 64 megabyte ram modules in them. They seem to be sram type chips. And they are probably giveaways at computer stores (I've seen people make 'tech jewelry' out of them). I wonder what it would take to interface to those modules? Lots of pins, so possibly some latches, but the modules would be free...
www.smarthome.viviti.com/build
Post Edited (Dr_Acula) : 11/5/2009 12:39:19 AM GMT
