Alternative to protoplug? (this is more available in my area) — Parallax Forums
noobmunchernoobmuncher Posts: 124
edited 2009-11-06 17:40 in Propeller 1
Hello,
I am starting out with Propeller chip and was wondering if I can make this work instead of the prop plug?
www.hvwtech.com/products_view.asp?ProductID=926
I realize the DTR is brought out instead of the RTS pin, but does that make a difference? If so can it be remedied?
Thank you!
  • BradCBradC Posts: 2,601
    edited 2009-11-03 02:51
    DTR is what you want in any case. All you need to do is add the little cap and transistor to properly reset the prop.
    If you always do what you always did, you always get what you always got.
    edited 2009-11-03 02:52
    What he said smile.gif ... but the pins are also in a different order on that usb adapter. I've used that exact adapter before.
    BradC said...
    www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
  • noobmunchernoobmuncher Posts: 124
    edited 2009-11-03 03:19
    Okay great thanks, and yes i noticed the order was different. Woot! Propeller programing here i come!
    edited 2009-11-03 05:20
    If you want something cheaper, see this (in the Completed Projects threads) - about $3 or you may have the bits already smilewinkgrin.gif
    Cheap propeller programmer...··http://forums.parallax.com/showthread.php?p=850099
    Note the section where they just used a cap for reset instead of the transistor, etc·(from DTR, not DSR)
  • dMajodMajo Posts: 862
    edited 2009-11-03 12:55
    Anyway DTR/RTS is the same: Propeller Tool give the choice to you (Edit menu/Preferences item/Operation tab/PropellerResetSignal)
    @BradC: it will be nice to have this option also on BST. This gives the opportunity to use the same serial line/port connected to two props and choose where to upload the application
    · Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
    edited 2009-11-03 14:30
    dMajo said...
    I've given it some thought and it's on my todo list. Do you really have 2 propellers connected to the same port and use DTR/RTS to select between them? Really?
  • Little-endianLittle-endian Posts: 91
    edited 2009-11-03 14:37
    This may also be another inexpensive option. I haven't tried this with the prop myself, but found it on their website:
    moderndevice.com/connect
    BradC said...
    dMajo said...
    No, but I have 2 props connected to the same cpld and the cpld to the max 3232 (the cpld, beside other things, do serial switching). I have tried several configurations. In the past (1994) when I was developing electromedical equipment (blood analysis) I had several 8051 mcu daisy chained on the rs232 serial bus. The 8051 uarts support 9bit mode for this purpose (addressing). On the board there was 2 db9 connectors going on the rx/tx pins through a max232 with an aux AND gate on the tx line. The communication was master/slave: all the slaves receive the message but only the addressed one answers. The master was a PC
