Alternative to protoplug? (this is more available in my area)
Hello,
I am starting out with Propeller chip and was wondering if I can make this work instead of the prop plug?
www.hvwtech.com/products_view.asp?ProductID=926
I realize the DTR is brought out instead of the RTS pin, but does that make a difference? If so can it be remedied?
Thank you!
Thank you!
If you always do what you always did, you always get what you always got.
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Cheap propeller programmer...··http://forums.parallax.com/showthread.php?p=850099
Note the section where they just used a cap for reset instead of the transistor, etc·(from DTR, not DSR)
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
@BradC: it will be nice to have this option also on BST. This gives the opportunity to use the same serial line/port connected to two props and choose where to upload the application
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
I've given it some thought and it's on my todo list. Do you really have 2 propellers connected to the same port and use DTR/RTS to select between them? Really?
moderndevice.com/connect
