Want to remotely control potentiometers, not sure how
Hi Guys,
As a musician, I use two effects pedals each of which has several pots to control various parameters.
While performing, I can't tweak these pots as I would have to bend down to do it. I was thinking that there must be a way to create a "pod" of some kind that I can mount on my mic stand, and each pot on the "pod"·would remotely control a corresponding pot on the pedal.
The actuators connected to the pedal pots would have to be mechanical in nature (as opposed to replacing the pots with electronics), because I would want it to be universal in nature... having the ability to fit the device(s) to any pedal or even an amplifier.
Essentially, if I turn pot 1 on the "pod" to 10:00, I would want the controlled pot to turn to 10:00. The assembly would have to rotate in very fine increments since I would be doing some fine tweaking of the controls for the sake of the overall balance of instruments. I'm basically looking for a 1:1 ratio so I always know how I'm set just by looking at the "pod" pots.
Can any of you steer me in the right direction? I was thinking of using a basic stamp II as a controller, but I also need ideas for the mechanical turning of the pots. Servos? Worm gears? I don't mind inventing something new if nothing exists already.
It absolutely doesn't have to be wireless in any way , unless that turns out to be easier to implement.
Thanks for any and all suggestions. Please respond even if your ideas seem a little outlandish. It's brain-storming time!
Thanks again,
Brian
Thanks again,
Brian
Have you looked at the Stomp-1 effects controller that uses a Propeller? In addition to just being a good effects controller, you could easily relocate the controls or even use something different since it's all digitally controlled anyway.
The two floor units that I use already have foot pedals, plus a main volume pedal, so the number of foot pedals is getting out of hand.
With a mic-stand mounted unit, I can tweak knobs during a slow part of the performance and also while I'm talking to the audience in-between songs. I could even adjust the gain on my amps with such a system. The single point of focus would be very helpful in seeing how things are set at a quick glance.
Thanks for the input!
Brian
That sounds like a good idea. I had a feeling a servo would be the answer. I have a Basic Stamp II mounted on a Board of Education, so I'll study up on reading pots with the rctime statement.
Would this method tend to drift out of calibration easily? Is there some kind of routine where calibration can be maintained in the interest of accuracy?
Finally, do you know offhand of any similar project either on the Parallax site or elsewhere so I don't have to reinvent the wheel? I know Google is my friend, and I will use it; I just thought you might be aware of something that can get me on the right track. I want to make sure I don't miss any resources.
Thanks for your help!
Brian
Edit: I think trying to hack that stomp box would be like opening a Pandora's box for me. Something tells me I should start from scratch.
www.servocity.com/html/servo_recorder_playback_contro.html
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Thanks a lot!
Brian
Thanks, that looks interesting but it looks like it will only rotate a servo 180 degrees, unless I can come up with some kind of linkage that would gear up the travel. It seems that most pots have a mechanical range of about 280 degress, give or take.
What about that servo tester in your signature? Wouldn't that accomplish what I'm looking for?
Thanks again,
Brian
My first thought would be to try to modify a servo for the extra travel, probably by replacing the existing pot and removing any mechanical stops.
At the extremes you can probably expect a servo to respond to pulses between ~ 500uS and ~ 2,500uS. Depending on what you use to drive the servo that could mean 2,000, 1,000 (Basic Stamp) or even only 200 (some servo testers) possible positions. The dead band of the servo will play an important part too. A standard servo may have a 10 uS dead band while a high end servo may only have 1us of dead band. Obviously, the high end servo will be more accurate. With a Basic Stamp and a standard servo I would think that you could get up to about 200 useful positions out of it - 100 each way, maybe more, maybe less. I don't know if that is fine enough control for what you are looking for. With a high end servo and a controller that works in 1uS steps, you might get up to 1,000 unique positions - but that may just be wishful thinking, and it would be expensive.
Rich H
Thanks to both of you for being available to us "newbies".
Brian
