looking for ideal stackable connectors
I need a surface mount through board connector that has:
32 or more pins 2 rows wide
2" or less long fine pitch would be preferable
a male counterpart can be found with very long pins.
the 966240-2000-AR-PR seems to fit these specs barely being 2" long with 40 pins but it is $5 each bying by the reel and that seems crazy. Any ideas for a cheaper version that may work better?
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
Post Edited (mctrivia) : 10/31/2009 10:10:32 PM GMT
Female: 956230-2020-AR - 2mm pitch, 30pos, 3.5mm tall - $3.09 in quantity of 200
Male: 951430-2062309-AR - 2mm pitch, 30pos, 15.9mm long if I remove middle peace - $2.91 in quantity of 200
with these parts my total board height is 5mm meaning I can stack 3 on top of the pins. I was hoping to be able to stack at least 4 and removing center support is not likely and easy or fun task.
