Wirewound as sense resistor
I have been using this one specific .1ohm 2w resistor and 1.21ohm I found at All electronics for several years now on some motor drivers. The current sensing IC with the .1 works incredibly well for what I need it to do. I remember reading somewhere a while back to avoid wire wound resistors, and to be honest I never knew these were wire wound until recently I had a driver IC go crazy and some hi and low mosfets were on at the same time, the resistor lit up and the coil was glowing red inside. I just ran out of resistors and need some more right away, and All Electronics is out (I live close by there so they are convenient). I need to order some online but figured I'd look into this warning I read about not using wire wounds. My theory is if it has worked great for 4 years now on various drivers, why bother changing, but I thought I'd see if there was any legitimate reason behind it.
If you still wish to use wirewound resistors for your application and are concerned about the related inductance, you may consider the "non-inductive wirewound" type. Check out the Vishay NS series (http://www.vishay.com/docs/30204/rsns.pdf). We used something similar in the automotive test group at Phillips Semi and had no problems with inductive effects.
DJ
Instead of:
"Those who can, do.· Those who can't, teach." (Shaw)
I prefer:
"Those who know, do.· Those who understand, teach." (Aristotle)
Post Edited (Todd Chapman) : 10/29/2009 9:03:00 PM GMT
DJ
Instead of:
I prefer:
These days I'm making all kinds of late-night mistakes, too. According to Child Services, diapering the wrong end of a baby at 3 am is far more serious than your minor miscalculation...
