Wirewound as sense resistor — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2009-10-30 18:45 in General Discussion
I have been using this one specific .1ohm 2w resistor and 1.21ohm I found at All electronics for several years now on some motor drivers. The current sensing IC with the .1 works incredibly well for what I need it to do. I remember reading somewhere a while back to avoid wire wound resistors, and to be honest I never knew these were wire wound until recently I had a driver IC go crazy and some hi and low mosfets were on at the same time, the resistor lit up and the coil was glowing red inside. I just ran out of resistors and need some more right away, and All Electronics is out (I live close by there so they are convenient). I need to order some online but figured I'd look into this warning I read about not using wire wounds. My theory is if it has worked great for 4 years now on various drivers, why bother changing, but I thought I'd see if there was any legitimate reason behind it.
    edited 2009-10-27 14:10
    Todd, as far as I recall the reason for avoiding wire wound resistors is due to their inductance. Not a problem for DC and low frequency circuits, but it may be an issue for high frequency PWM control. Never run into problems myself, but I have always avoided wire wound sense resistors for any but DC or 60HZ circuits.
    edited 2009-10-27 18:09
    Todd,
    If you still wish to use wirewound resistors for your application and are concerned about the related inductance, you may consider the "non-inductive wirewound" type. Check out the Vishay NS series (http://www.vishay.com/docs/30204/rsns.pdf). We used something similar in the automotive test group at Phillips Semi and had no problems with inductive effects.
    DJ
    Instead of:
    "Those who can, do.· Those who can't, teach." (Shaw)
    I prefer:
    "Those who know, do.· Those who understand, teach." (Aristotle)
    edited 2009-10-27 20:24
    I have used 3 silicon diodes as a simple on/off current sensor. Schematic attached shows 3 series diodes (1N4001 or equivalent, current rating needs to match your application) in motor circuit. Obviously the diodes·slow your motor down slightly, you'll lose about 2 volts from your motor battery supply. But you can feed the top diode connection·into a stamp input pin through a 1K protection resistor, and you'll read logic 0 when the motor is off and 1 when the motor is on.
    325 x 200 - 6K
  • T ChapT Chap Posts: 4,260
    edited 2009-10-29 20:57
    Thanks guys for that info. I have been looking at substitutions since I ran out of the surplus 1.21ohm wirewound I had a lot of. Digikey doesn't carry anything at 1ohm current sense in 3w, only goes to 2w. I am thinking now that this wirewound I had must be a 2 watter. I can't find anything on it online marks: ULT or ULI CS-4 1.21ohm wirewound. Maybe get one of the 2 watters from digi, non-inductive wirewound and test it.
    Post Edited (Todd Chapman) : 10/29/2009 9:03:00 PM GMT
    edited 2009-10-30 03:55
    In theory a 1ohm 2W resistor would be good for up to 2A, although in practice I would not use it for much more than 1A if the current draw is continuous for long periods.
    edited 2009-10-30 16:23
    kwinn - how do you figure that 2 amps?
    DJ
    Instead of:
    I prefer:
    edited 2009-10-30 17:28
    Power dissipated through a resistor is resistance times current squared, so I make max current for that 2W 1 ohm resistor to be 1.414 amps.
    edited 2009-10-30 17:56
    davejames, erco, thanks for catching my error. I should know better than to send late night answers without double checking them.
    edited 2009-10-30 18:00
    kwinn:
    These days I'm making all kinds of late-night mistakes, too. According to Child Services, diapering the wrong end of a baby at 3 am is far more serious than your minor miscalculation...
    Erco, that is so true.
