Connecting power ground to logic ground - good idea? bad idea? or just plain ug
Greetings,
I'm designing a PCB that uses a Power Logic 8-bit Shift Register known as a TPIC6595, chip. It's basically a shift register with mosfets built into it. My question is this: should the TPIC6595's power ground (which is being dumped on by the mosfets) be tied into the logic ground (which is the side being controlled by a Propeller, so it would be the Propeller's Vss.)? I know I've been told in the past that logic grounds and power grounds should not be the same, but other Propeller-controlled mosfets that I've used in the past have required that the Propeller's Vss be tied to the negative side of the power that is being switched by the mosfet. So I'm confused on how to handle this. The TPIC6595's data sheet (attached) mentions something about preventing cross-talk between the logic ground and power ground, but how is that done? Must I add some kind of bypass capacitors or what?
thanks for your wisdom on this,
Mark
Watching the world pass me by, one photon at a time.
Mark
Logic grounds on pin 19 connected to the power ground at a single point on the PCB.
A .01uF bypass cap between Vcc and logic ground on each chip.
All 4 power ground pins should be connected to the power ground.
A 0.1uF bypass cap between the power V+ and power ground on each chip.
An on board electrolytic capacitor (1000 + uF) on the V+ supply.
Awesome! Yes, now I see that resistor you mentioned. Thank you very, very much for the tips on how to do this correctly!
Mark
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
Very good point. Thanks for bringing that up.
If that is not a mess of noise, then nothing is.
But some how computers run fine.
Optical isolators are one way to trigger a gate and not tie the LOGIC to the POWER.
In many comercial buildings for computer outlets the ground is isolated all the way back to the main panel.
Hmmm. Sorry, but I've grown a little bit confused about these bypass caps as I started laying out the PCB. The heaters which these TPIC chips are controlling with PWM are located about 1 foot away from the actual PCB that the TPICs are mounted to, so the power V+ cable that goes to those heaters is somewhat far away from the TPIC chips. Should I run a cable from power V+ to the chips just so I can connect the 0.1uF bypass caps? or did you mean to say "Vcc" and not "power V+" ???
Also, if "power V+" is correct, wouldn't a bypass cap from power V+ to power ground possibly degrade the PWM signal? I'm only using 100 Hz PWM so maybe that wouldn't be an issue anyway, but I thought I'd better ask.
thanks,
Mark
Wow! That's great news. Thanks for the super-speedy reply. I'm at my desk doing the layout right now and I was afraid I'd have to fret over this all weekend.
Thanks for the super awesome assistance!
Have a Happy Halloween!
